Go to Post What is this? PVC pirates with no visible PVC? (at least that I can see) IMPOSTORS! - theawesome1730 [more]
Unread 07-02-2013, 21:58
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Getting distance to the goal
Just wondering what other teams are using/have used to get the distance to the goal. If I have the distance to the goal I can throw the distance into my equation for our shooter and spit out the angle I need the shooter at to make the shot. Really, my quesetion is what is the most efficient manner when using vision processing to get the distance to the 3 ptn frisbee goal? I'm using java right now (doing a build on labview and java)
Any help is much appreciated!
Unread 07-02-2013, 22:54
bgg's Avatar
bgg bgg is offline
FRC #3679
bgg is an unknown quantity at this point
Re: Getting distance to the goal
We've used a sonic rangefinder which came with fewer headaches but less sophistication and detail than vision processing. This might get the job done for what you need. Mount it centered on the front of the bot and the distance to the wall can be used for calculating shooter speed/shot distance. A voucher from MaxBotix was included in KOP and might be a sensible solution.
Unread 08-02-2013, 12:09
DjMaddius's Avatar
AKA: Matt Smith
Well, we used one of those last year, but if anything gets in the way, a frisbee or a bot or even the pyramid, it will return a false distance. So I was thinking of going with the photon cannon idea and using the distance between the top and bottom retroreflective tape to give me my distance using some basic trig functions. I was just seeing if there were any very efficient algorithms on doing this. I don't want it to take up a ton of processing obviously.
Unread 08-02-2013, 12:27
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Most teams I have talked with plan on using the pyramid to their advantage when lining up a shot. I think its a great plan.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 08-02-2013, 13:13
DjMaddius's Avatar
AKA: Matt Smith
I agree, but I'd like to be able to shoot from wherever, speeding things up ten fold.
Anywho, I found the whitepaper on tracking,
http://firstforge.wpi.edu/sf/go/doc1302?nav=1
I don't quite understand the whole distance calculations where they are getting the width of the entire field of view.
Unread 08-02-2013, 14:00
DjMaddius's Avatar
AKA: Matt Smith
Alrighty, I think I've got it, I'll upload my java class in a few, its untested but theoretically works. I'll have to test it tomorrow at our meeting.
Unread 08-02-2013, 16:58
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
I am very interested in seeing this as I am having difficulty doing this with vision processing.
https://kusha.me
Unread 08-02-2013, 17:02
Quenty's Avatar
Quenty Quenty is offline
FRC #1984 (Raider Revolution Robotics)
Quenty is an unknown quantity at this point
I think there's a java API out there, but I'm not sure what it's called. D:
Unread 08-02-2013, 17:38
Justin m's Avatar
Justin m Justin m is offline
FRC #2028 (Phantom Mentalists)
Justin m is an unknown quantity at this point
What the you have to do is determine the width of the target in pixels, given a constant value w/ the target centered, and find the hypotenuse, which is your distance
EDIT: Use the height for distance, not the width.The width can vary with angle to the target.
Example:
Note, these are necessary constants
    public static final int IMAGE_WIDTH = 320;
    public static final int IMAGE_HEIGHT = 240;
    public static final double TARGET_WIDTH = 2.0;
    public static final double TARGET_HEIGHT = 1.5;
    public static final double RECTANGLE_QUALITY_THRESHOLD = 95.0;
    public static final double PARTICLE_TO_IMAGE_THRESHOLD = 0.05;
    public static final double PARTICLE_AREA_THRESHOLD = 250.0;
    protected double fieldOfViewWidth = 0.0;
     * Return distance to target in inches
     * @param targetHeightInPixels
     * @return
    public double GetDistanceToTarget(int targetHeightInPixels)
        double fieldOfViewHeight = TARGET_HEIGHT / targetHeightInPixels * IMAGE_HEIGHT;
        distance = (fieldOfViewHeight / 2.0) /
                 * tan 23.5 degrees
                  0.4348123749;
        return distance * 12.0 * 1.4;
I am assuming you can figure out how to filter for targets.
Unread 08-02-2013, 19:16
DjMaddius's Avatar
AKA: Matt Smith
Appreciate the reply's! Sorry it took a few hours for me to post the code, left for a few hours for dinner and such..
package org.first.team2620;
import com.sun.squawk.util.MathUtils;
import edu.wpi.first.wpilibj.DriverStationLCD;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.camera.AxisCamera;
import edu.wpi.first.wpilibj.camera.AxisCameraException;
import edu.wpi.first.wpilibj.image.BinaryImage;
import edu.wpi.first.wpilibj.image.ColorImage;
import edu.wpi.first.wpilibj.image.CriteriaCollection;
import edu.wpi.first.wpilibj.image.NIVision.MeasurementType;
import edu.wpi.first.wpilibj.image.NIVisionException;
import edu.wpi.first.wpilibj.image.ParticleAnalysisReport;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
 * @author frc2620
public class CameraDistanceCalc {
    private AxisCamera camera_;
    private CriteriaCollection cc;
    private DriverStationLCD b_LCD;
    public CameraDistanceCalc(AxisCamera cam)
        camera_ = cam;
        cc = new CriteriaCollection();
        cc.addCriteria(MeasurementType.IMAQ_MT_BOUNDING_RECT_WIDTH, 30, 400, false);
        cc.addCriteria(MeasurementType.IMAQ_MT_BOUNDING_RECT_HEIGHT, 40, 400, false);
        b_LCD = DriverStationLCD.getInstance();
        b_LCD.updateLCD();
    public CameraDistanceCalc(String cameraIP)
        camera_ = AxisCamera.getInstance(cameraIP);
        b_LCD.updateLCD();
    public double calcDistance()
        double distance = 0;
        try
            ColorImage image = camera_.getImage();
            //ColorImage image;
            //image =  new RGBImage("/10ft2.jpg");
            //BinaryImage thresholdImage = image.thresholdRGB(25, 255, 0, 45, 0, 47);   // keep only red objects
            BinaryImage thresholdImage = image.thresholdRGB(0, 45, 25, 225, 0, 45);     // Keep only green objects
            BinaryImage bigObjectsImage = thresholdImage.removeSmallObjects(false, 2);  // remove small artifacts
            BinaryImage convexHullImage = bigObjectsImage.convexHull(false);            // fill in occluded rectangles
            BinaryImage filteredImage = convexHullImage.particleFilter(cc);             // find filled in rectangles
            ParticleAnalysisReport[] reports = filteredImage.getOrderedParticleAnalysisReports();  // get list of results
            ParticleAnalysisReport ThreePtn = reports[reports.length-1]; // Reports is listed by largest to smallest area in the rectangle, 3 ptner should be the smallest area
            double tw = 4.5;
            double tpw = ThreePtn.boundingRectWidth;
            double cw = 320;
            double WFOV = tw * (cw / tpw);
            distance = (WFOV / 2) / (MathUtils.atan(27 * (Math.PI / 180)));
            System.out.println(filteredImage.getNumberParticles() + "  " + Timer.getFPGATimestamp());
            SmartDashboard.putNumber("Number of Particles: ", filteredImage.getNumberParticles());
            SmartDashboard.putNumber("Height:  ", filteredImage.getHeight());
            SmartDashboard.putNumber("Width:   ", filteredImage.getWidth());
            SmartDashboard.putNumber("Distance:", distance);
            filteredImage.free();
            convexHullImage.free();
            bigObjectsImage.free();
            thresholdImage.free();
            image.free();
        } catch (AxisCameraException ex) {
            ex.printStackTrace();
        } catch (NIVisionException ex) {
        return distance;
I have not tested this, though if you need help let me know! I should be able too.
Unread 10-02-2013, 22:26
DjMaddius's Avatar
AKA: Matt Smith
Has anyone tested my class I made? I'd like to know any results you have from it. I haven't had a chance to try it yet, other things have out weighed it.
Unread 13-02-2013, 21:50
nyaculak nyaculak is offline
FRC #0053 (Area 53)
nyaculak will become famous soon enough
Team 53 is going to mount the XBOX Kinect directly on our robot and use OpenCV and an on-board computer (Beagle Board) to process our images.
2013 MUC DC 3rd Place, FRC DC Regional, FRC Chesapeake Regional
2012 FRC DC Regional, FRC Chesapeake Regional
ERHS Robotics Club
- FRC Team 53 "Area 53"
www.erhsroboticsclub.org
Unread 13-02-2013, 23:14
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
I wouldn't recommend this. We used one last year. We had issues with teams on our alliance driving in front by accident, throwing our shooting off. Near the end of the second regional, we started to clue in that we should probably tell our alliance partners about it. Turns out this was a bad idea. Teams we played with in one match, and against in later matches (including eliminations) only had to SIT infront of us to throw our shooting off.
We had to fall back on our preset shooter values, which weren't nearly as accurate or tuned in as our values from our ultrasonic. We spent all of lunch after alliance selections at our second regional tuning our presets, which we almost entirely used in our elimination matches.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 14-02-2013, 10:28
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Example:
     * @return
                 * tan 23.5 degrees
                  0.4348123749;
However the height varies as well depending on the height of your robot and how close you are to the target.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 14-02-2013, 11:43
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
you see, this is what our team did last year, we built a very complex robot (one that had the shooter able to turn, change the angle, had a range finder, camera, etc.) and we ended up not doing too well at competition because the programming was too complex for the programmers, all i'm saying is, if it doesn't work out, shoot from the front or back of the pyramid and have a set angle and speed, that is what we are doing, good luck!
