Go to Post The only teams who have no chance of winning are those who believe they can't win. To quote the greatest athlete of our generation: "Limits like fears are often just an illusion." -- Michael Jordan - Karthik [more]
Unread 08-02-2013, 15:13
neil4751 neil4751 is offline
FRC #4751
neil4751 is an unknown quantity at this point
cRIO not responding
When we try to deploy our code from Labview to the cRIO, we get a message that says "Waiting for real-time target to respond". The communications light in the driver station is green. We've tried rewiring the router, and restarting our cRIO and router, but it still doesn't work.
This issue happened last week too, but it went away the next day, and it seems to be back today.
Anyone know how to fix this issue?
Unread 08-02-2013, 15:34
Re: cRIO not responding
Have you installed the latest (5.1) LabVIEW update? It was just released this past week. One of the things it fixes is an inability to replace existing code when a Dashboard program is open.
Unread 08-02-2013, 15:41
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
We've had this problem with all three of our cRIOs since the update. Reimaging them seemed to fix it.
Unread 08-02-2013, 15:44
FRC #4751
We have that update, and we tried re imaging it.
Some additional details I forgot to add:
We changed Ethernet cables and we don't have crossed cables. This occurs both when we "Run as Startup", and when we run from "Robot Main.vi".
Unread 08-02-2013, 15:56
Close the Dashboard program before trying to deploy code. If that works, you probably either haven't successfully installed the update, or you haven't built the code since installing it.
Unread 08-02-2013, 16:03
FRC #4751
We've tried deploying with the dashboard closed, and it still doesn't work.
