Go to Post Yeah After we decided not to do autonomous, the robot took matters into it's own hand. i'd bet it would get it's self DQ'd... or an award. - GMKlenklen [more]
Unread 08-02-2013, 15:26
Team UPDATE - 2013-02-08
http://frc-manual.usfirst.org/Updates/0#term%2077
Additional details about the robot access periods for district systems and new Java and C++ software updates.
Unread 08-02-2013, 15:35
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Team UPDATE - 2013-02-08
For programmers, the update is detailed here, Ctrl-F "2nd Midseason C++ and Java Update" for the release notes. Download here for java and here for C++.
Changes that effect C++ and Java:
Subsystems being put to SmartDashboard to show their status now only update on changes reducing the network traffic substantially. Putting a subsystem to SmartDashboard will allow you to see the command that is current "requiring" that subsystem to better understand what your program is doing.
The Scheduler instance can now be put to SmartDashboard using SmartDashboard:: PutData() for C++ or SmartDashboard.putData() for Java. Putting the Scheduler to SmartDashboard shows what commands are running in real time so you can better understand what your program is doing.
SmartDashboard.jar (the client-side program) has been updated to reflect the above changes.
RobotBuilder now supports higher CAN IDs
RobotBuilder generated The C++ PIDGet method is now generated with the correct case.
RobotBuilder Gyro object is now limited to the correct analog ports.
RobotBuilder generated gyro sensitivity now matches the 2013 kit part.
The use of the SmartDashboard features for viewing the Command System can be found here.
C++ only:
The GetError method on PIDControllers along with OnTarget would hang due to a bug in the synchronization. That is now fixed and GetError and OnTarget should now work properly.
Reading numeric values from Number arrays in NetworkTables would return an incorrect value and occasionally fail due to a race condition. Both of these errors have been fixed.
GetRawRGB method returned incorrect values. That has been corrected.
A bug with noticing value changed on the Preferences class has been corrected.
Java only:
Fixed a bug with recursive put when removing values from Preferences
Java - The update can be installed by updating your current version of the plugins in NetBeans or for computers not connected to the internet, downloading the plugins from here.
All opinions are my own.
Unread 08-02-2013, 16:01
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
Still no Digital Media.
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
Unread 08-02-2013, 16:05
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
With less and less time to prepare an actual submission, winning this award this year will be a crapshoot...
That said, a teams' media efforts have year-round importance far beyond winning an award.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
