Go to Post "If you abuse the easy button, you become it." / "What does that mean?" / "We hit you and you say 'That was easy'" - ScoutingNerd175 [more]
Unread 07-02-2013, 22:21
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
Virtual cRIO (cRIO Emulator)
I have created a Virtual cRIO so you can test your robot code without having to wait for the mechanical and electrical teams to finish their jobs.
This is the first release so do not expect it to work flawlessly!
Download: http://www.mediafire.com/?wpwkpreo6hwjc16
Instructions:
- Download the jar file and place onto desktop
- Open netbeans (or other IDE)
- If using netbeans either create a new robot project or use an existing project
- Once your robot project is created right click on the project you just made and click properties
- Click on Libraries, and remove the classes.jar library and add the Virtual cRIO.jar
- Once the library is added make sure there are no errors with the class imports
- Now you have to create a new file in the src folder by right clicking the src folder and New -> Other -> Other -> Empty file, name it main.txt
- Now in that file put <PackageName>.<MainClass> but replace PackageName with the actual package name and the MainClass with the main class that extends SimpleRobot and then save the file
- Now all you have to do is click the build icon (the one that looks like a hammer)
- Now open Virtual cRIO.jar and click the Choose Jar button
- Find your built robot project which is usually in your documents folder under netbeansprojects/<Project Name>/dist
- And now you should be able to enable the cRIO!
If you are having any trouble or having any problems please be sure to leave a comment below so I may assist you!
Screenshot:
Unread 08-02-2013, 11:32
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Virtual cRIO (cRIO Emulator)
Where is "libraries" under the Project properties? I only have
General
Java Sources
Java Sources Classpath
Output
Build & Run
Formatting
(none that i can find contain classes.jar anywhere)
Unread 08-02-2013, 12:21
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Awesome project! However, I'm running on ubuntu, java can't find the main class to execute the software. Secondly, same issue as above. Can't wait to use it once these issues are addressed!
Unread 08-02-2013, 15:53
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
After build season, I'd like to help with one of these projects. It seems nobody accounts for the squawk libraries, which astonishes me. Although this library is impressive for what it is, there is a whole lot more that needs to be made. If you really need to test it on your computer, you are probably using more obscure libraries, which these kinds of things just don't do very well. Like I said, I'd love to help if its open source.
All opinions are my own.
Unread 08-02-2013, 16:25
General
Java Sources
Output
Build & Run
Formatting
Right click on your project and click on properties. Sorry for not clarifying that.
Unread 08-02-2013, 16:38
I think the error here is that i compiled it with JRE 1.7 and you probably have JRE 1.6. Is the error something like this: "java.lang.NoClassDefFoundError" If so that is most definitely the issue.
Unread 08-02-2013, 16:41
DjMaddius's Avatar
AKA: Matt Smith
Yep, running jre 1.6
Unread 08-02-2013, 20:21
So im guessing now its working??
Unread 08-02-2013, 20:26
DjMaddius's Avatar
AKA: Matt Smith
Haven't installed jre 1.7 to try
Unread 09-02-2013, 18:26
There will be network support in a later release and i might make it so the driver station will be able to connect to the virtual cRio!
Unread 09-02-2013, 20:43
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
thats what i did?
Unread 09-02-2013, 21:25
thats what i did?
And you cant find a section thats named Libraries?
Unread 09-02-2013, 22:28
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
no. theres only
General
Java Sources
Output
Build & Run
Formatting
and as far as i can tell, none of them contain a "libraries"
Unread 10-02-2013, 11:39
no. theres only
Ok I have found the issue, you are using an older version of netbeans which looks like this:
And the version of netbeans we are using looks like this:
Now all you have to do differently is go to Java Sources Classpath and do what I say in my original post!
Unread 10-02-2013, 12:09
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Nope, im running JDK 1.7 and my "Java Sources Classpath" is much different than the one you have shown, it only contains 2 files for the wpilibj and networktables libraries.
