Go to Post Who has time for boredom? - Dr Theta [more]
Unread 08-02-2013, 16:38
ghostman126 ghostman126 is offline
ghostman126 is an unknown quantity at this point
Re: Suction gripper
Originally Posted by bardd View Post
I have no experience with suction grippers so I can't help you, but I'd like a link to the manual/game details of the competition. Maybe I'll come up with an idea or notion you can use for inspiration, and it would also be a good excersize for years to come
The rules can be found here: http://jsdc.ec.illinois.edu/news/201...petition-rules It's pretty long but the important stuff is under III Match rules. Pretty interesting imo
Unread 08-02-2013, 21:58
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
Re: Suction gripper
Wow I read the manual of you guys' game! You guys can have weapons? I would suggest you guys have swerve drive as well on your robot so you guys can maneuver past and easily dodge your oponents' attacks.
I also suggest things like padding on the exterior of your robot so you can lower the force dealt from the impulse of an attack.
Is there a limit to how many cones you can put on a pole at a time? If not, you can put on a bunch at a time so no others can fit.
This territory game looks fun.
P.S. College students get all the fun...
Unread 08-02-2013, 22:06
Re: Suction gripper
We don't get to use weapons during the actual game. After the competition, there is a demolition round where we can use weapons. A great way to end the competition every year. As such we are using omni drive so that we can solve the tasks rather than worrying too much about weapons etc. You can put as many cones as you want on a rod but you only score points by getting as many cones on top of the rods as possible. Here's the map if you are interested http://www.flickr.com/photos/eohjsdc...in/photostream
After discussing I think we may go ahead with our friction gripper as it may be much more simpler/efficient. We could also modify our gripper to get or place one cone/a whole stack of cones at one go.
Unread 09-02-2013, 07:10
Team Role: CAD
Re: Suction gripper
With a little innovation, an inside gripper can be easier to make and more efficient than the friction gripper. To pick up stacks of cones, just have the claw be made around a hollow pole so it can go down one of those poles. Also, check out Team 16's 2011 robot. They had a claw that could even pick up deflated tubes and I think their inside gripper used only one actuator. I think it's on YouTube just type in Bombsquad 2011 Robot Unveil.
Unread 13-02-2013, 02:15
Re: Suction gripper
So yep, here's an update. Before I started this thread, we already bought some stuff to test out the suction. We first got the vacuum pumps off sparkfun: https://www.sparkfun.com/products/10398 and we tested them without anything. They felt weak and we lost hope so I started this thread to look for alternatives. Today, we got our hands on the suction cups and we decided to try it for fun, here was our setup vacuum pump, 12v, some tubing and piab pigrip suction cups.
these were the piab suction cups
and when we tested them...
they worked really well! There are few small things such as not sucking the cones when the cups are placed on the part of the surface with ridges, but we can get by it! Thank for all your help
Unread 13-02-2013, 08:19
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Re: Suction gripper
I think that a gripper like this would probably be pretty successful.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Re: Suction gripper
I would actually recommend against swerve drive unless you have prior experience with it--too many points of failure; it isn't robust in my experience. (Granted, we only tried it once. There are plenty of teams with better designs than ours).
If you use a gripper tht expands to hold the inside of the cones, make sure you can place them on the rods and retract your claw without pulling the cones back off the rod. That happened a lot in 2011 for inside grippers.
Unread 08-02-2013, 22:59
Re: Suction gripper
Hmm we are actually thinking of using an outside high friction gripper. We have the exact cones and they are very flexible. With enough friction you can squeeze them from the stack and place them down/pick them up one by one.
But yea we also need to pick up stacks of cones so we need a mechanism to grab the whole. They aren't very heavy and we may use the inside gripper mechanism together with our single cone high friction gripper. If it's too hard to use the inside gripper (as the stack of cones we need to pick up from are placed in a rod itself, so you gotta make sure you don't hit the rod) we may just use a big claw and grab the whole lot from the bottom. The cones are really light and small thankfully.
Unread 09-02-2013, 02:02
T^2 T^2 is offline
FRC #5499
Re: Suction gripper
If you want high-friction material, I recommend this stuff. It grips frisbees incredibly well, and I see no reason it won't do the same for cones.
