Go to Post If there are no top tier teams, then who do we look up to for inspiration? - artdutra04 [more]
Unread 08-02-2013, 16:41
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Re: Bonding polycarbonate to polycarbonate
Originally Posted by Andy A. View Post
IPS Weld-On #16 works pretty well on polycarb. #'s 55 and 58 work even better. They're all 'solvent' cements, which likely means something like Methylene Chloride is the active ingredient. The nice part is that the heavier glue base is much easier to work with then a pure solvent.
I was looking around for something else and found IPS Weld-On #4 recommended with a needle bottle applicator. From McMaster-Carr, it would be 7517A1 for 4 oz of adhesive ($8.79, water-thin) and 1902T41 for the needle bottle ($6.67). Recommendations online are to clamp the parts together and run a very tight bead of solvent down the seam, letting the adhesive wick into the joint.
MSDS #1 - http://www.curbellplastics.com/techn...c-weldon-4.pdf
MSDS #2 - http://www.tapplastics.com/uploads/p...%204%20New.pdf
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
