Go to Post your robot may have a bit of a "pimpwalk" - GMKlenklen [more]
Unread 08-02-2013, 16:53
Schnyde Schnyde is offline
FRC #2856
Schnyde is an unknown quantity at this point
Network Table Help
I'm trying to send data from the Labview driver station to a cRIO running on Java. I've found that my options are Network Tables or TCP. I'm trying to do Network Tables, but can't seem to figure out how exactly to do it, especially on the Labview side. Does anybody have any advice or suggestions on this? Thanks a lot.
Unread 08-02-2013, 18:10
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Re: Network Table Help
Hey, check out this post I put on my image processing walkthru.
That posts a few doubles to the ST networktable under each of their respective labels, from x1, y1 to x4, y4 and the range.
Unread 08-02-2013, 20:37
If you modify the LabVIEW Dashboard project you can make use of the Network Tables "SmartDashboard" with just about zero effort. Just place a control or indicator on the front panel, and don't wire it to anything. It'll automatically become a SmartDashboard variable, having its value shared with the cRIO's program.
Unread 08-02-2013, 22:15
FRC #2856
Thanks so much!
