Go to Post I have no desire to watch a battle of who sucks less. - Cory [more]
Unread 08-02-2013, 17:03
brrian27's Avatar
brrian27 brrian27 is offline
the Mormon
AKA: Brian
FRC #2383 (Ninjineers)
brrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond repute
VEX 2-Wire Motor 393 Help
Hey, so we're interested in using a vex 2-wire motor 393 and we're wondering how to wire it? Any help?
team2383.com
2011-14: Student- Team 2383, the Ninjineers (2013-14: Drive Team Coach & 2014: Co-Captain)
5 Team Spirit Awards --- 1 Excellence in Engineering Award --- 1 Regional Finalists
Currently : Student- Brigham Young University
2015 SOUTH FLORIDA REGIONAL CHAMPS #BLUEBANNERYEAR ARCHIMEDES DIVISION FINALISTS
Unread 08-02-2013, 17:09
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
Re: VEX 2-Wire Motor 393 Help
The only power regulating devices for actuators permitted on the ROBOT include:
Jaguar motor controller (P/N: MDL-BDC, MDL-BDC24, and 217-3367),
Victor 884 motor controller (P/N: VICTOR-884-12/12),
Victor 888 motor controller (P/N: 217-2769),
Talon motor controller (P/N: CTRE_Talon and am-2195),
VEX motor controller (P/N: 276-2193) for controlling VEX 2-wire Motor 393 (P/N: 276-2177) only, and
Spike H-Bridge Relay (P/N: 217-0220).
So basically you can use the provided vex motor controller and go straight into a dsc or use a motor controller/ spike relay
Unread 08-02-2013, 17:10
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
You'll need one of these:
http://www.vexrobotics.com/vex/produ.../276-2193.html
Then, you'll wire that to a PWM port on the digital sidecar. Make sure to insert a jumper to power the motor.
Unread 08-02-2013, 17:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Can the digital sidecar supply the 4.8 Amps this motor pulls at stall?
Unread 08-02-2013, 18:52
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
No, it cannot. 3.0 Amps is all the digital side can handle.
Also note that that motor is rated at 7.2 volts.
The "servo" jumper for power on the digital side car will provide 6.5 volts.
You'll be be able to run it at a lower voltage, as such a slightly slower RPM.
As long as it's not bound up, then the brief stall at start-up won't be a problem.
I would also put a 2.5 - 3.0 AMP fuse inline with the power lead for this motor.
You'll blow the fuse before tripping the sidecar.
So simply put, don't stall it.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 09-02-2013, 02:29
Is there another legal way to supply current to this motor so it can be supplied its spec'd voltage and full stall current? Wire to the PDB and use an 8-Volt regulator or something? Would that be legal?
Unread 09-02-2013, 07:33
I don't think so. I believe the options are 6V from the DSC through the Vex controller or 12V from another power regulating device(spike/victor/etc.).
Unread 09-02-2013, 11:47
Phalanx's Avatar
We spent a few hours looking for a voltage regular to do just that without any success. We even looked into making our own voltage divider, but we simply could find resistors that could handle the wattage and be able dissipate the heat generated.
So we basically said... Ok. Well use it at 6.5 volts with an inline fuse.
6.5 volts is 90% of 7.2 volts so you'll get 90% of what you'd expect from that motor. It will be something like 140rpm instead of 160rpm.
