Go to Post Michigan teams will eat your souls. You have been warned. - MishraArtificer [more]
Unread 08-02-2013, 18:54
rhp3794 rhp3794 is offline
rhp3794 is an unknown quantity at this point
Question pneumatics doubt
hi everyone
i've got a doubt with putting the compressor in periodic task, because as you know the limit is 120psi , does the compressor stops when it arrives to 120psi?? or do we need to program that? help please
Programming Leader
Team 3794
WinT
Unread 08-02-2013, 19:01
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
The compressor control loop, what you place in periodic tasks (there already should be one there in a disabled structure), has an internal loop so it will run and check the state of the pressure switch every X seconds.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 08-02-2013, 19:05
Re: pneumatics doubt
X = 1 second
Unread 08-02-2013, 21:51
DonRotolo's Avatar
Back to humble
FRC #0832
Note that there is a pneumatic pressure switch (mandatory if using any pneumatics) that senses 120 PSI and sends a signal to the cRio via a digital input on the sidecar. The default code has this all built in, it's well-documented...
