Go to Post What we may be looking at is a confusing situation and that can be confusing. - JaneYoung [more]
Unread 08-02-2013, 21:10
TeamDrift4091's Avatar
TeamDrift4091 TeamDrift4091 is offline
FRC #4091
TeamDrift4091 is an unknown quantity at this point
pic: Team Drift 4091 Crate Stand
Unread 08-02-2013, 21:11
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: pic: Team Drift 4091 Crate Stand
Looks like a cool idea, but how will you make sure this stays under the 400lbs limit (if using the FedEx FIRST agreement). and where would this be going in your pits? it seems like it would be a little big for you to have an space in your pits
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 08-02-2013, 21:16
FRC #4091
It is already build, and is all aluminum under 200 pounds + robot under 80 pounds because we are using carbon fiber this year is way under 400 pounds. And sizes is according to pit size.
Unread 08-02-2013, 21:19
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Your robot is under 80 lbs this year? I'm not saying that's impossible, but as we weighed it out, the controls alone are about ~50lbs so that's one small robot.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 08-02-2013, 21:31
FRC #4091
Yes is small and our shooter was build using small wheels and bag motors, we are not picking Frisbees from floor and our 30 point climbing mechanism is using winches.
Unread 08-02-2013, 21:33
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
It's totally possible. We will have to add ballast to make it to 80lbs.
Unread 08-02-2013, 21:34
FRC #4091
also we made our own transmisions using aluminum gears
Unread 08-02-2013, 22:07
What do you intend to use all the dead space behind it for?
Unread 08-02-2013, 22:11
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
Remember the weight of the bumpers. assuming you will be storing them in there.
FRC #4091
that does not count in the robot weight.
Unread 08-02-2013, 22:12
FRC #4091
tools
Unread 08-02-2013, 22:45
But it would count toward crate weight--40 lb total if you had 2 sets at max weight.
Unread 09-02-2013, 01:07
FRC #4091
Thanks for the comments, we are aware about weight of the crate the robot. Just wanted to share what we have done.
