Go to Post Seasons are often made or broken in the first week of build season. 1114 wouldn't be repeatedly giving their strategic design seminar if it wasn't that important. - Knufire [more]
Unread 08-02-2013, 22:09
quando04's Avatar
quando04 quando04 is offline
Head Programmer - Robodogs
AKA: Quan Do
FRC #2579 (Robodogs)
quando04 is an unknown quantity at this point
Exclamation How to bring power to the Axis Camera
I want to bring power t the Axis 206 Camera. I cut and stripped the wire off from the camera power adapter. However I do not know which wire is positive or negative. Can anyone help me?
Unread 08-02-2013, 22:17
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
Re: How to bring power to the Axis Camera
Take a look at the molded plug, it should have a marking showing the polarity. The center should be positive while the outside should be ground. Now use a multimeter set to continuity tester and probe from one end to the other (connector to cut/stripped end). Once you wire it up, ensure voltage and polarity per the markings before plugging it into the camera.
Unread 08-02-2013, 22:18
mocibot's Avatar
mocibot mocibot is offline
FRC #1829 (Carbonauts)
Team Role: Student
mocibot is just really nicemocibot is just really nicemocibot is just really nicemocibot is just really nice
I don't know if the Axis Camera has it on it, but most devices I've seen on the sticker with the electrical specs (ie. input 5V 600mA etc.) have a picture of the plug and which part is positive and negative. From there, you could use a multimeter to find out which wire is on the outside of the barrel plug, and figure out if it's positive or negative.
This should work, definitely as a starting point. I didn't do my teams so anyone who wants to confirm or deny this method please do.
Edit: This post confirms that the center of the plug should be positive. Sorry for the double answer, I check to see if anyone had responded, and they hadn't. But iambujo did between then and my posting.
Good luck, stay safe, learn new things, and have fun!
I'm a student, because I don't fit in any one category.
Unread 08-02-2013, 23:51
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Also, the positive wire for the camera will have a white stripe down the side of it. (Negative will have no stripe or markings) This stripe can be solid or dashed - but as stated before, double check the polarity before plugging it into the camera.
I'm right 90% of the time, so why worry about the other 3%?
