Go to Post If you're sore over the vigorous defense teams play, get over it. It happens and will continue to, as the majority of people hope. - AmyPrib [more]
Unread 09-02-2013, 10:39
Mr.Roboto3335's Avatar
Mr.Roboto3335 Mr.Roboto3335 is offline
Wait, What?
AKA: Jimmy
FRC #3335 (Cy-Borgs)
Mr.Roboto3335 is an unknown quantity at this point
Servo programming
I'm having trouble trying to program a servo. Everytime I press the button that should make it rotate it does nothing. Any help would be appreciated.
/* Copyright (c) FIRST 2008. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Servo;
import edu.wpi.first.wpilibj.SimpleRobot;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the SimpleRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class RobotTemplate extends SimpleRobot {
Servo servo = new Servo(5);
Joystick joystick = new Joystick(1);
* This function is called once each time the robot enters autonomous mode.
public void autonomous() {
* This function is called once each time the robot enters operator control.
public void operatorControl() {
if(joystick.getRawButton(3))
servo.set(1);
else if(joystick.getRawButton(4))
servo.set(-1);
* This function is called once each time the robot enters test mode.
public void test() {
Wait, what?
Unread 09-02-2013, 11:28
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Servo programming
servo.set(1);
servo.set(-1);
This should be running in a loop. Like this
while(isOperatorControl()) {
    // Code here
All opinions are my own.
Unread 09-02-2013, 11:33
Wait, What?
AKA: Jimmy
You are absolutely correct. I forgot that statement. Servo still won't work. It doesn't even default when I reset the robot. Wiring?
Wait, what?
Unread 09-02-2013, 11:43
Also, Servo.set() takes a value from 0 to 1, rather then -1 to 1 like a motor.
You can also use code tags to keep your formatting when posting code.
Did you install the servo jumper in the digital sidecar?
Unread 09-02-2013, 11:48
Wait, What?
AKA: Jimmy
No I did not... Found and inserted the jumper and is now working. Thank you!
Wait, what?
Unread 17-02-2013, 19:24
tmccalister tmccalister is offline
FRC #2985
tmccalister is an unknown quantity at this point
What is a servo jumper? If you could help me with that just pm me. Thanks
Unread 17-02-2013, 19:28
Jump to 0:24 in this video:
http://www.youtube.com/watch?v=RF104...me0nC_xUILWCam
Unread 18-02-2013, 18:36
FRC #2985
What does it look like?
Unread 18-02-2013, 21:02
It looks like the picture in the 2013 Kit of Parts black tote checklist revB.
