Drive System--Variable to Speed Controller
Hello everyone,
I am trying to take a value from a variable that I have transfered from the usual "Joystick.getY();" command and input it into the speed controllers but I am getting the following error: "cannot find symbol symbol: method leftSpeedController(double)" from this line in my code: "leftSpeedController(dJ1Y);". Here is a bigger segment the bigger picture of what I am trying to do. public class DriveSubsystem extends Subsystem { // BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS SpeedController leftSpeedController = RobotMap.driveSubsystemLeftSpeedController; SpeedController rightSpeedController = RobotMap.driveSubsystemRightSpeedController; // END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS // Put methods for controlling this subsystem // here. Call these from Commands. public void initDefaultCommand() { double dJ1Y; //Variable that will house the y-axis number of //driverJoystick1. double dJ2Y; //Variable that will house the y-axis number of //driverJoystick1 // BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND // END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND // Set the default command for a subsystem here. //setDefaultCommand(new MySpecialCommand()); //leftSpeedController = Robot.oi.driverJoystick1.getY(); //gets the position of //driverJoystick1 and puts it into the variable dJ1Y. dJ1Y = (Robot.oi.driverJoystick1.getY());//gets the position of //driverJoystick2 and puts it into the variable DJ2Y. leftSpeedController(dJ1Y); } } I know there has go to be some common sense answer to this problem that I am missing, but I can't figure it out. Any help would be greatly appreciated. Thanks!! |
Re: Drive System--Variable to Speed Controller
You can't put leftSpeedController(double) on that line near the end. You need to call a method from that object that sets its speed to the double. I havn't worked with robot builder or whatever you're using but NetBeans should give you a list of options if you type "leftSpeedController." I'm guessing it will be "leftSpeedController.set(double);" set(double speed) being the method you actually want. What you're telling it to do right now is to call the method leftSpeedController(double d) which is non-existent.
