Go to Post There is almost always more than one solution to any engineering problem. One part of elegant design is picking the one that makes the most sense for a particular design problem, even if that means "breaking" some normally established "rules". - Jeff Pahl [more]
Unread 09-02-2013, 14:22
vic burg's Avatar
vic burg vic burg is offline
Alumni, Mentor, & AmeriCorps VISTA
AKA: Captain Obvious
vic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to behold
Robot twitched and now is not responding
On Thursday we had a working robot and it was twitch when it was first enabled. We tried to fix this error by changing the safety to be a periodic task. Now, nothing is responding. We checked both batteries and recharged them thinking that may have been the problem but that is not it. It used to have a whine when it was enabled but that is gone now. We have very basic coding. The drive motors are CIMS and the launcher we have tried miniCIM, CIM, Window and gear motors but nothing is working. We have double checked all of the wiring and fixed one issue but still no response. We have tried to fix code but there are no errors. The victors (3 888's) all have flashing orange lights. The Jaguar is hard to tell if it's a yellow/green or an orange flashing light.
Rookie team here, I am the only mentor but it has been 5 years since I've even touched an FRC robot so any help would be fantastic.
RoboColts--Hallandale Elementary
--Thanks goes out to Cody C for making me ^^this^^ user bar!!!!
Nuts and Bolts help the world go 'round.... They also keep us all together. Including the Robots we build. -vic burg
I have been dubbed an honorary member of 1902 and 744 (by the members).
And yes, I am in the habit of collecting team t-shirts.
Unread 09-02-2013, 15:16
Re: Robot twitched and now is not responding
If you want to isolate code from electrical issues, you may want to try Test mode. Set the DS to test mode and enable it. See if the motors work correctly when you select a Output Value in the dashboard tab, set the speed, and enable.
If you are pretty sure it is code, consider posting a picture or the code. In particular, I'm not sure what safety in a periodic task may mean.
Greg McKaskle
Unread 09-02-2013, 15:34
vic burg's Avatar
When we do the test, the motors do not do anything, it's like we didn't change the values at all. It shows:
Victor[1,5]
Analog[1,8]
Jaguar [1,1]
Jaguar [1,3]
Jaguar [1,2]
Jaguar [1,4]
However, we have 3 Victors and 1 Jaguar - is this the error? Our programming computer does not have internet connection so it's hard for us to do screen shots, which is a huge pain.
