Go to Post Why is the battery labeled "battery"? - Vermeulen [more]
Unread 09-02-2013, 14:51
Re: |Calculating Distance to targets
Assuming the image element you are measuring is the retroreflective rectangle, you need to reconsider its physical height. I believe it is 12" inside the tape plus 4" tape on each side.
As mentioned, there are other sources of error, but I suspect those will be pretty small, definitely not 2 meters of error.
Greg McKskle
