Go to Post If you are new to these forums, you might want to observe the discussions a while before diving in with opinions, emotions, and expertise. - Andy Baker [more]
Unread 09-02-2013, 15:27
Nathan Powell's Avatar
Nathan Powell Nathan Powell is offline
The Prime Function
FRC #2582 (PantherBots)
Nathan Powell is an unknown quantity at this point
Windriver C++ Assistance
I've run into a slight issue--My team is in need of more workspaces to archive code with, but I never learned how to create new ones. May someone offer assistance? Any information on creating projects and .cpp/.h files would be useful, as well.
Unread 09-02-2013, 15:28
The Prime Function
Re: Windriver C++ Assistance
Note--I know how to create an example project; I would like information on creating other types of projects, please. The FRC manual is not very specific on this.
Unread 09-02-2013, 17:40
AKA: Brad
#0190 ( Gompei and the Herd)
The idea is to start with one of the samples that are provided in the C++ FRC distribution, then modify it into your program by adding all of your specific robot code.
You can get an idea by looking at this page:
http://wpilib.screenstepslive.com/s/...-robot-project
Brad
Brad Miller
Robotics Resource Center
Unread 09-02-2013, 18:05
The Prime Function
That I do understand. I use the templates there as bases for my code. Do you know how to create a new workspace? There can only be one of each example per workspace.
Unread 11-02-2013, 11:22
AKA: Brad
If you go to the File menu, and select Switch Workspace, you can put in a path to a new workspace. It will create the directory, set it as your workspace, and Workbench will restart. Then you can start creating projects in the new place.
Brad
Brad Miller
Unread 14-02-2013, 18:53
dhe95 dhe95 is offline
FRC #2637 (Panthers)
dhe95 is an unknown quantity at this point
After you make an example project, you should rename it to something more appropriate and then you can make more while keeping them all in the workspace if needed.
And to add .cpp/.h files you would just do new file and name it with the right extension
