Go to Post ...It's two years old, but GP is GP. - Brandon Martus [more]
Unread 09-02-2013, 14:16
bhughes bhughes is offline
bhughes is on a distinguished road
60 / getPeriod() returns 3,000,000
We have encountered a problem where doing this:
double getRate() {
    return 60 / counter.getPeriod();
Randomly returns 3,000,000 sometimes. We're using it to determine how accurate our bang-bang is by averaging the difference between the setpoint RPM and the real RPM, and it works well until at seemingly random times it will return strange high numbers. Other than the high numbers, it returns accurate ones. We are using a once-per-rev hall effect sensor and we've gotten (by graphing the data) within 20+- rpm of what we'd like. The random large numbers mess up our data, and we're wondering what would cause this to happen.
This is getPeriod():
public double getPeriod() {
    double period;
    if (m_counter.readTimerOutput_Stalled()) {
        return Double.POSITIVE_INFINITY;
    } else {
        period = (double) m_counter.readTimerOutput_Period() / (double) m_counter.readTimerOutput_Count();
    return period / 1.0e6;
How would m_counter.readTimerOutput_Stalled() return true? That's when it is considered "stopped", correct?
Unread 09-02-2013, 14:28
Re: 60 / getPeriod() returns 3,000,000
double getRate() {
What is your setpoint rpm?
How fast is your wheel spinning when this glitch happens?
Unread 09-02-2013, 14:30
4500rpm for both questions. It gets to the setpoint far before the glitch happens.
Unread 09-02-2013, 14:36
How fast are you running the control algorithm. i.e., at what rate are you calling counter.getPeriod()?
Unread 09-02-2013, 14:38
We've tested at the 20ms periodic methods (removed all other code), and still seen the problem.
Unread 09-02-2013, 14:49
What's the part number of your Hall sensor?
Can you post a picture of how you have the magnet mounted to the wheel.
Working hypothesis: vibration is randomly causing the sensor to read the rising edge twice.
Unread 09-02-2013, 15:10
We purchased the one pictured here from their team. (it is a newer "version", but as far as I can tell the same hardware components.) I seem to remember it having this sensor, but I could be wrong. This is what it looks like when mounted.
Unread 09-02-2013, 15:28
I can't tell for sure from the angle the picture is taken at, but it doesn't look like the Hall sensor is mounted in the correct orientation relative to the magnet. Could you post a couple of pics taken from x,y,&z directions?
Also, it looks like the Hall end of the PCB is unsupported and the Hall chip is dangling at the end of its long leads. It could be vibrating. Try stuffing some tissue paper under the leads to dampen it and see if it makes a difference. Easy enough to try.
Unread 09-02-2013, 15:37
Here's an album.
We'll try and dampen the vibration. Right now that seems to be the most likely cause.
Unread 09-02-2013, 16:17
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
You definitely don't have the Hall sensor oriented correctly. The "flat" part of the sensor should be perpendicular to the magnet. If you don't bend anything, then the correct orientation is with your mounting board parallel to the face your magnets are mounted on. Preferably with all those components on the side facing the wheel.
Or, you can bend the Hall sensor backwards, towards the back of the mounting board, away from the side all the components are mounted from.
(30 seconds later) EDIT: Also, why not put something in your GetRate function that tosses out obviously incorrect values like a period less than 0.0001 seconds or something?
Unread 09-02-2013, 16:25
It's better to understand what's causing the problem, fix it if you can, and make it work right than to cover up the problem.
But if you do filter out the glitches in software, then increment an error counter each time it happens. Monitor that error counter during non-competition use to make sure it isn't getting worse and worse over time.
Unread 09-02-2013, 17:19
Thanks guys. We mounted it horizontally and added tissue to relieve vibration. The bug hasn't come up since. We're actually within 2-5rpm from our setpoint, which is awesome.
Unread 09-02-2013, 17:35
Can you post some pics please
Unread 09-02-2013, 18:42
agrees well with a simple ballpark calculation:
Unread 09-02-2013, 22:34
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
We had the same problem as the OP last year, with a similar data resolution, and this year (our values were more like 90,000 RPM). This is what we've done, for lack of a better solution.
EDIT: We're using LabVIEW, and the Counter class's Period output (from the Get.vi).
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
