Go to Post You get to see great matches at the Championship event regardless of a people's choice event. - Yan Wang [more]
Unread 09-02-2013, 16:40
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Run Command Once When Trigger is Pressed
How do i make it so that a command runs once when the trigger is pressed?
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 09-02-2013, 16:47
Re: Run Command Once When Trigger is Pressed
Set a boolean TRUE on rising edge of trigger, and
Run the command when the boolean is TRUE and set the boolean OFF after running.
Unread 09-02-2013, 16:49
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
yourTrigger.whileActive(yourCommand);
Unread 09-02-2013, 16:50
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
krieck is an unknown quantity at this point
Try:
Joystick stick = new Joystick(1);
JoystickButton trigger = new JoystickButton(stick, 1);
trigger.whenPressed(new MyCommand));
Unread 09-02-2013, 16:58
inkspell4's Avatar
Could you give me an example of how to do this
Unread 09-02-2013, 17:02
If you're using the Command Based templates I second what Kriek is suggesting.
Ether's suggestion is the generic description of exactly what Kriek
suggestion does for you.
Unread 09-02-2013, 17:12
inkspell4's Avatar
It doesn't work because the execute command keeps going on. Is there a way to stop the execute command and make the subsystem revert to the default command.
Unread 09-02-2013, 17:14
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
refer back to my first post.
Unread 09-02-2013, 17:15
inkspell4's Avatar
Will that work even if the command takes more time to execute than the trigger is held for?
Unread 09-02-2013, 17:20
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
No.
if you use whenPressed (or whenActive), it will activate when the button is pressed and wont stop untill isFinished returns true
if you use whileHeld (or whileActive), it will activate when the button is pressed and wont stop untill isFinished returns true OR the button is released (if the button is released, the command is cancelled but the "end" method will not run and the "interrupted" method will. Keep that in mind when setting things like shooter jags)
Unread 09-02-2013, 17:21
AKA: Brad
#0190 ( Gompei and the Herd)
Here is an example of running commands whenever a joystick button is pressed. You can also associate commands with buttons from the Cypress module or any arbitrary polled trigger (see Trigger class).
http://Wpilib.screenstepslive.com/s/3120/m/7952/l/97457
Besides using whenPressed() you can also call whenReleased() to get a command to run when the button is released or whileHeld() to get a command to repeatedly run while the button is pressed.
Brad
Brad Miller
Robotics Resource Center
That's what isFinished() is for.
Unread 09-02-2013, 17:22
inkspell4's Avatar
Forgot about that, Thanks
Unread 10-02-2013, 19:54
Peragore's Avatar
Peragore Peragore is offline
CEO of Black Magic
AKA: Philip Mulford
FRC #3373 (Team Robohawk)
Peragore is an unknown quantity at this point
Probably already solved, but what I would do is assign a flag to whether the code is required to run. so, when the trigger is pressed (>= .01, maybe), you set the flag to true. the method runs when the method is true, and at the end of the method, it sets the flag to false. Granted this is using SimpleRobot template.
while (life){
  frcObsession = true;
  obs.ProgramAndObsess();
if (!life) life = true;
Unread 12-02-2013, 20:35
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Simply set the isFinsihed() method to return true;
The execute method will run once, isfinsih() will be true and then the command will call the end() method and die.
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
