Go to Post If there is anything I have learned from ChiefDelphi, it's to never underestimate the coding genius that is Brandon Martus. - Amanda Morrison [more]
Unread 31-01-2013, 18:34
JesusC JesusC is offline
FRC #4633
JesusC is an unknown quantity at this point
Ultimate ascent options?
I have a questions for you guys, is it possible to just remain shooting frissbees while the call to ultimate ascent has happened.
I mean, if you dont do the climb, can you shoot frisbees while the other robots struggle to climb to the top
Unread 31-01-2013, 18:36
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Re: Ultimate ascent options?
There is no call to climb. You can climb at any time, and you are not required to climb at any point in time. If your strategy allows, it may give you more points to shoot rather than climb.
Unread 31-01-2013, 18:38
MOOcow's Avatar
MOOcow MOOcow is offline
AKA: Cliff
FRC #1986 (Team Titanium)
Team Role: Electrical
MOOcow is an unknown quantity at this point
You can continue shooting through the 30 second buzzer. You aren't *required* to climb at the buzzer.
Unread 31-01-2013, 22:46
GaryVoshol's Avatar
Cogito ergo arbitro
Nor are you required to wait for the 30-second sound before climbing. It only signals when Feeders can throw the discs over the Alliance Station Wall.
(since 2004)
Unread 01-02-2013, 16:51
FRC #4633
allright, thank you, i think that if you can shoot frisbees well enough, the climb is not really worth it. Because if you can hit the piramid goal multiple times in the time it takes you to climb, it really is not worth it, is it?
Unread 01-02-2013, 16:57
BobbyVanNess's Avatar
BobbyVanNess BobbyVanNess is offline
AKA: Bobby Van Ness
FRC #0020 (The Rocketeers)
BobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of light
Keep in mind, you can only use the six alliance color discs when scoring in the pyramid. they are worth 5 points each. If you can score all of them successfully (requires 2 trips, because you can only handle 4), then the points value is equivalent to a third level climb. That being said, if you can quickly climb the first level (all you have to do is get the bot completely off the ground), then that gives you a 10 point bonus, which may be beneficial to do in the last few seconds.
2016 TVR Finalists, FLR Champions, Carver Sub-Division
2015 TVR Finalists, Carson Sub-Division Champions, IRI
2014 TVR Champions, FLR Champions, Archimedes Division, IRI
2013 WPI Regional Finalist, Connecticut Regional Champion, Archimedes Division, IRI
2013 Championship and IRI Talent Show winner
2013 - 2014 Driver: 82-43
Lead Strategy Mentor: 32-15
Unread 01-02-2013, 16:59
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
It depends. If you are playing to be chosen by a team, a good shooter with decent auto will be good. If you want to be in the top eight you need to look at how they calculate rankings.
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 09-02-2013, 19:45
FRC #4633
Wait, so you are telling me that we can only shoot the six coloured Frisbee at the pyramid, and everything else at the wall, can you please tell me where this is in the rules, I didn't see this.
Unread 09-02-2013, 19:50
You can shoot the colored frisbees into any goal for points. However, they are worth the most in the pyramid goals (5 points as opposed to 3 points). White discs do not score points in the pyramid goals.
Let me rephrase the sentence that was giving you confusion: "Keep in mind, you can only use only the six alliance color discs when scoring in the pyramid." (Misplaced modifiers tend to lead to ambiguity--anybody in an English class, take note.)
Unread 09-02-2013, 19:59
FRC #4633
thank you, that definitely helps, otherwise, we would have wasted our time shooting white discs into the pyramid
Unread 09-02-2013, 20:29
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
Why not climb, then proceed to shoot freebees? maximum points!
"No, you can't use the Kinect to do pelvic thrusts."
Unread 09-02-2013, 20:38
AKA: Bobby Van Ness
You mean shooting while hanging? You would only be able to take a maximum of 4 shots, unless you climb back down, making the whole climb pointless.
