Go to Post The robot competition is the most obvious, visible, and distilled-media-friendly part of the picture... We shouldn't be surprised that it's all that gets into the news coverage, when that coverage is managed by someone who isn't already well versed in what FIRST is trying to do. - Alan Anderson [more]
Unread 09-02-2013, 17:04
Whateveryousay's Avatar
Whateveryousay Whateveryousay is offline
Team 1683 Techno Titans
AKA: Tony Chen
FRC #1683 (Techno Titans)
Whateveryousay is an unknown quantity at this point
pic: 1683 30-Point Climber
Unread 09-02-2013, 17:06
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: 1683 30-Point Climber
Solid frame! Are those center omni wheels just place holders or actually what you will be running?
Mentor 2415
Unread 09-02-2013, 17:56
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I'm a little confused by the omni wheels as well. Are they not powered? It looks like the power take off/Super shifter doesn't have a direct drive output to those wheels.
I'm interested in seeing this climbing mechanism, not really sure how the string works.
Unread 09-02-2013, 18:26
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I think the string is being used more like a belt. You can see what's going on on the far side. The string is run through an eyelet, then tied off onto the pivot for that big cylinder. Said pivot is set up to run in a slot along the frame. So I think this is a belly climber that's using air and a PTO. That's my read on the arrangement of things anyways. I'm not entirely sure how they get onto the first rung and ratchet up, however.
Unread 09-02-2013, 20:23
AKA: Tony Chen
We are using those omni wheels for the competition.
2011 Peachtree Regional Innovation in Control Award
2011 Peachtree Regional Semifinalist
2010 Peachtree Regional Champion
2010 Peachtree Regional Creativity Award
2008 Peachtree Regional Finalist
2007 Bayou Regional Champion
2006 Peachtree Regional Finalist
2005 Peachtree Regional Quarterfinalist
Unread 09-02-2013, 20:24
AKA: Tony Chen
Indeed they are not powered, the string does work like a belt, sliding the end of the two 10'' pistons along the side of the robot
Unread 09-02-2013, 20:26
AKA: Tony Chen
Sir, you are correct. As for the first rung, we will let the pistons assume a straight up 90% angle first, the cylinders will extend, just enough to hook on to the first rung, and we will fire the cylinders, pull the robot half way up. We also have a kickstand mechanism in the middle of the robot, which will make our robot parallel with the 68 degrees angle. And at this point, the wrench will start pulling and that would get our front wheels past the first rung, engaging our passive hook.
Unread 09-02-2013, 22:43
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
...Why? It really doesn't help you out any.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 09-02-2013, 23:02
John Sabath's Avatar
John Sabath John Sabath is offline
LabVIEW Software Developer
FRC #3792 (The Army Ants)
John Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to behold
I've seen similar configurations before, so I'm assuming this one is no different.
The omni-wheels in the center are slightly lower than the traction wheels in the front and the back. The bot doesn't use all 6 wheels simultaneously. Personally, I don't see the advantage over a basic 2 omni 2 traction drive, because they'll both end up handling the same way.
Unread 09-02-2013, 23:13
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
The configuration you're describing is typically done with all traction wheels, colloquially known as dropped-center 6wd. The purpose of lowering the middle wheel is so you can use all traction wheels while still being able to turn.
The issue with putting all the wheels in the same plane is that it becomes very difficult to turn, because you are trying to drag the corner traction wheels sideways along the ground while you turn. The traditional method of doing 6wd with omnis is to put the omni-wheels in the corners, so that they roll side to side when turning.
Putting the omni-wheels in the center only hurts you. If you don't drop the center wheels, they would never scrub sideways so you get no benefit, and only lose traction. If the center pair of omnis is dropped, the turning center of the robot will change drastically depending on which set of traction wheels are in contact with the ground at the time. This would probably be very hard to control.
I would strongly suggest that 1683 test this on their carpet at the full robot weight to see how it performs. If the center omni is not dropped, I suspect you will find it very hard, if not impossible, to turn. If the center omni is dropped, I suspect it will drive pretty erratically.
Unread 10-02-2013, 01:51
Shane 2429 Shane 2429 is offline
FRC #2429
Shane 2429 is infamous around these partsShane 2429 is infamous around these parts
the 6 wheel drop drive is also commonly refereed to as west coast drive or wcd
Unread 10-02-2013, 01:55
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Being a 6wheel-drop-drive and WCD are two different things (but not mutually exclusive). You might read one of the 800 threads on it to understand the differences, but there are differences between a standard 6WD and WCD(besides the fact WCD can have 8 wheels...)
Unread 10-02-2013, 12:33
AKA: Tony Chen
Thank you, we will do the testing really soon. The center wheels are dropped by 1/8'', last year we had trouble turning with 6 wheels all pneumatics and center dropped. We only solved the problem when we center-dropped more than 1/4'', so this year we are going to try this configuration.
Unread 10-02-2013, 12:51
Nuttyman54's Avatar
Mentor, Tactician
Pneumatics wheels can be very tricky to get to work in a dropped center configuration (just ask 233 about their 2006 robot!) because they squish. This is good for traction, but it can effectively eliminate the "drop" that enables you to turn. Your issue wasn't that all-traction wheels didn't work, but that your center wheel squished down and took away an 1/8" of drop.
You're on the right track to solving the issue by placing a non-pneumatic wheel in the center so it won't squish down, but you don't need an omni there. I think you'll find much better performance if you swap it out for a treaded traction wheel, like the Plaction or Performance wheels from AndyMark or a Traction Wheel from VexPro.
They won't squish down, so you'll still get all the maneuverability of the drivetrain you have with the omni, but they'll have better traction and your robot won't try to turn about the outer edges of the frame.
Hope this helps you guys some, best of luck this year!
The pneumatic wheels are less forgiving than most wheels in terms of how far you have to drop them.
