Go to Post Its always reassuring to share a design with a respected, competitive and veteran team. - Adama [more]
Unread 09-02-2013, 21:10
treeturtle1 treeturtle1 is offline
FRC #1780
treeturtle1 is an unknown quantity at this point
Robot Not Enabling
Greetings Friends,
We just installed the new cRIO II, and imaged and deployed our code, but when enabling the robot on the Driver Station, the DS says that the robot is enabled, but the Jaguars are still blinking instead of turning solid. The code is C++ on WindRiver and compiles, but I am wondering if this is a cRIO or other aspect of the control system that isn't allowing the Jaguars to be responsive.
If anyone has any thoughts, please let me know! Thank you dearly.
1780
Unread 09-02-2013, 21:15
Re: Robot Not Enabling
Does the DS show that the robot has code and is enabled? Is it in teleop? Can you put in some printfs or LCD messages or stay connected to the code in the debugger to determine what your code is doing?
Greg McKaskle
Unread 09-02-2013, 21:55
FRC #1780
Yes, the DS has communication with robot and code, and successfully enables, but nothing results of it. I got frusterated and tried reimaging the cRIO but the imaging failed and corrupted the image so I am trying to successfully reimage it currently, but from what I remember there didn't seem to be any errors other than a sporatic radio error in teleop. We tried both wireless through the router and then a direct tether to the cRIO but it was the same result.
Unread 09-02-2013, 22:08
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Make sure that all three lights are on on the digital sidecar
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 10-02-2013, 12:24
For some reason, reimaging the cRIO always seems easier than debugging and fixing the issue, but it is rarely the cause of the issue unless SW is out of date. And because of the IP addresses, it actually isn't that easy or foolproof to reimage.
Focus on reimaging the cRIO back to where you had it. You will need to put the computer and cRIO on the same subnet and ensure that other network options such as wireless are disabled and ensure that the wired ethernet doesn't have more than one IP address set.
Then we can resume debugging the original issue.
Greg McKaskle
Unread 26-06-2014, 17:58
iKiel2012 iKiel2012 is offline
FRC #1073 (The Force Team)
Team Role: Electrical
iKiel2012 is an unknown quantity at this point
I think this happened to me at comp once. Someone must have pressed the space bar which is the emergency stop, and nothing was happening. We rebooted our cRIO and it worked. It may or may not be something as small as that.
Unread 02-07-2014, 23:50
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
Are the modules in the correct slots on the cRIO?
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 03-07-2014, 01:11
dmaciel10123 dmaciel10123 is offline
The Everything Guy
AKA: David Maciel
FRC #3525 (The Nuts and Bolts of Fury)
dmaciel10123 is an unknown quantity at this point
If you try to enable and the DS enables but quickly disables you could also check your periodic tasks or any other loops you have. Running the loops too quickly can cause that.
