Go to Post Unsure if I'll get it to work, but that's no reason to not try. - DonRotolo [more]
Unread 09-02-2013, 19:51
cvessalico cvessalico is offline
FRC #0884
cvessalico is an unknown quantity at this point
Team 884 30 pt Climber Testing
Its not quite done a few more guard rails and a dumper will be added. Nemo kept us out of the shop last night and today . Hope to have it finished up by Wednsday night. Here is the video:
http://www.youtube.com/watch?v=WEPJk...ature=youtu.be
Unread 09-02-2013, 19:55
DBortnick's Avatar
DBortnick DBortnick is offline
AKA: Daniel
FRC #1850 (Mechanicats)
DBortnick is on a distinguished road
Re: Team 884 30 pt Climber Testing
14 Airtanks!
Love the claws. Great job! I'm really pleased to see all of these climber designs, I'm a bit jealous!
Coach for Team 1850
ACE Technical Mechanicats - Chicago, IL
http://www.facebook.com/Team1850
Unread 09-02-2013, 19:59
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
You guys might want to look at using several single solenoids so you can use lower pressure air for extending your cylinders. That would drastically cut down on your air consumption, and it's not like you need the full 60 psi for extending the cylinders.
Unread 09-02-2013, 20:15
FRC #0884
Thanks thats a good idea cause it takes us 6 minutes to charge all the tanks and we would love to use less of them. I'll mention it to the team
Unread 09-02-2013, 20:26
Trick is that you have to regulate upstream from the solenoid valve. Putting a regulator downstream from the valve can make strange things happen. So you'd basically have a bank of solenoids under 60psi pressure and all attached to the retract side of cylinders and a bank of solenoids under 15-20psi pressure all attached to the extend side of the cylinders.
Unread 09-02-2013, 20:43
commodoredl commodoredl is online now
AKA: Dan Lavoie
FRC #2877 (LigerBots)
commodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud of
Be careful about where the bottom part of your robot rests... Remember that if any part of your robot (including wheels or bumpers) is at or below the plane going across the TOP of the middle rung, you will only get 20 points. Make sure the whole robot is fully elevated so you don't get any unfortunate surprises at the competition!
Technical Mentor
Team 2877 - Ligerbots
2016-
Previously:
Team 578 - Red Raider Robotics
2007-2014
Unread 09-02-2013, 21:58
FRC #0884
The lowest part is about 2" over the middle rung
Unread 10-02-2013, 14:42
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
A 30pt climb is impressive!!! And your robot looks very clean
Unread 11-02-2013, 21:03
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Holy airtanks!! It might be a little late now but you can get a 1 gallon metal tank that should hold all of your air that weighs less than all of those tanks combined, and looks cooler
Sweet climber though, you guys do that quick!! If you really want to save air you could invest in spring extension cylinders that only use air on the way in and a spring going out, we thought about it until our 30 pt climber got scrapped.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 12-02-2013, 00:15
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Where can I get one?
FRC Team 4334
2012 - Archimedes Champions, IRI Champions
2013 - Western Canadian Regional Winner, Galileo Quarter-Finalilst
Unread 12-02-2013, 01:09
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
A quick search showed me this tank. Might be a problem for Canada, but they do have trucks with air brakes there, right? Might be as simple as hustling down to a Peterbilt dealer and see what the repair shop can rustle up.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 12-02-2013, 08:27
FRC #0884
Thanks for the comments. We are looking into getting a new tank and cylinders now but with our limited rescources and this late in the game might not happen before end day!!
Unread 12-02-2013, 08:50
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
14 of the 41 cubic inch tanks they're using equals 574 cubic inches.
1 gallon is 231 cubic inches.
Might want to do a few calculations on required air consumption before committing to the 1 gallon tank.
2007 - Rookie All Star - Bayou Regional (1858 - Tyborgs)
2009 - Rookie All Star - Bayou Regional (2992 -Prometheus)
2010 - Champions - Bayou Regional (2992 -Prometheus)
2012 - Finalist - Bayou Regional (2992 - Prometheus)
team2992.com/design.php
Unread 12-02-2013, 08:58
FRC #0884
We are looking at some 2.5 gallon tanks
Unread 12-02-2013, 19:19
neshera's Avatar
neshera neshera is offline
Nesher G. Asner
AKA: Nesher G. Asner
FRC #1625 (Winnovation)
Team Role: Parent
neshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud of
Is your robot too wide to fit inside the top of the pyramid?
Do not panic! All is well!
- Kevin Bacon in Animal House
