Go to Post We need to all remember we are no better than our fellow man, no matter what job we all hold, what socio-economic status that's involved, or anything. Plain and simple, we're all fellow travelers on this pale blue dot called Earth. - trobots.com [more]
Unread 09-02-2013, 22:03
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
pic: Shot of the electrical board before it goes on the robot
Unread 09-02-2013, 22:05
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
Re: pic: Shot of the electrical board before it goes on the robot
No pneumatics? I don't see any relays.
Also, I love your colourful ribbon cable!
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 09-02-2013, 22:10
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
What is the color coding on your resettable fuses for
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 09-02-2013, 22:16
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
If you notice that the associated PWM Cables share the same color code in electrical tape. This is a simple way to keep track of the wiring for a single component.
If you have a problem with motor "red-blue" you can easily check "red-blue" cables, fuses and motor controllers. It is easy and cheap to debug a system and replace components.
If your team does not utilize an on robot wire labeling system, I strongly advise you do before it is too late. Even if your wiring is neat and orderly.
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 09-02-2013, 22:46
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
That ribbon cable is just fabulous.
Edit: ....And the electronics board is nice too
https://kusha.me
Unread 09-02-2013, 22:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I like the colour coding, but be nice to your inspectors and leave the current ratings of the fuses uncovered.
Unread 09-02-2013, 23:15
Responses in order of the posts above:
- No pneumatics. The last time the team used pneumatics was 2007!
- As McGurky said, the color coding follows the entire path for a single motor or sensor. Marking tape was applied directly to every motor and sensor. It was then applied to the ends of the wires on the robot, near the connectors to the board. Obviously, you can see it applied to the wires on the board near the connector, to both ends of the PWM cables, on the breakers, and directly on the controllers themselves. For debugging purposes, you can't get much easier than that!
- We had two choices for ribbon cable... the rainbow one we got from FIRST Choice, or the plain gray one that was in the KoP. Needless to say, the students chose to go colorful.
- The current ratings are a good point, they went a little overboard on labeling a few of the fuses. Fortunately, we only use 12 and 14 gauge wire, so there's really no possibility of an issue with any of them!
2016: Lake Superior WFFA
Unread 09-02-2013, 23:22
Twins Inc.'s Avatar
Twins Inc. Twins Inc. is offline
wait....are you a twin??
AKA: Zach Larson
FRC #2605 (Sehome Seamonsters)
Twins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really nice
Hinges?
Unread 09-02-2013, 23:33
Yup. The board will be mounted to the very bottom of the robot. While the important stuff is visible from above, it's not very accessible. So, we can tip the robot on its side, remove a couple of bolts from the non-hinged side, and fold the entire electrical board down to work on it if something goes wrong. Note the PowerPole connectors... they run near the hinge, with built in slack to ensure they don't get pulled tight or come apart when the board is lowered. They also allowed us to complete all of the wiring (on both the board and the robot) before putting the board on, and finish it by snapping a few connectors together.
