Go to Post Competition isn't about the resources you don't have, it's making the most out of what you do have. - CalTran [more]
Unread 09-02-2013, 23:43
Twins Inc.'s Avatar
Twins Inc. Twins Inc. is offline
wait....are you a twin??
AKA: Zach Larson
FRC #2605 (Sehome Seamonsters)
Twins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really nice
Shortening Cim Motor Axel
Are we allowed to trim down a Cim Motor axel (BAG Motor)? We're making a belt driven wheel thats in a tight spot and the axel is too long.
Unread 09-02-2013, 23:47
bgg's Avatar
bgg bgg is offline
FRC #3679
bgg is an unknown quantity at this point
Re: Shortening Cim Motor Axel
Yes. See rule below:
R33
The integral mechanical and electrical system of any motor may not be modified. Motors, servos, and electric solenoids used on the ROBOT shall not be modified in any way, except as follows:
The mounting brackets and/or output shaft/interface may be modified to facilitate the physical connection of the motor to the ROBOT and actuated part.
The electrical input leads may be trimmed to length as necessary.
The locking pins on the window motors (P/N: 262100-3030 and 262100-3040) may be removed.
The connector housings on the window motors (P/N: 262100-3030 and 262100-3040) may be modified to facilitate lead connections.
The Integrated Encoder Module (P/N: 276-1321) may be installed on the VEX 2-wire Motor 393 (P/N 276-2177).
The VEX 2-wire Motor 393 (P/N: 276-2177) gears may be changed or replaced per the Supplier instructions.
Unread 10-02-2013, 23:25
DonRotolo's Avatar
Back to humble
FRC #0832
Axel
Axle
Note the differences.
Unread 10-02-2013, 23:37
Chris is me's Avatar
AKA: Pinecone
Frankly, I am beyond impressed that you found an application for the BAG motor where the shaft was too *long*. The short output shaft has been a problem for any of our potential uses.
Unread 11-02-2013, 00:05
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Originally Posted by DonRotolo View Post
Axel
Axle
Darn it, now I have to go listen to Axel's theme...
But I also have to agree with Chris. What on earth do you have attached to the BAG motor that can drive something, but still needs the shaft shortened?
I'm right 90% of the time, so why worry about the other 3%?
Unread 11-02-2013, 03:24
Johnny's Avatar
Johnny Johnny is offline
We do it for the pizza
FRC #1266 (The Devil Duckies)
Johnny has a spectacular aura aboutJohnny has a spectacular aura aboutJohnny has a spectacular aura about
I can see the axle needing to be shortened if they are trying to fit it inside say a banebot or andymark planetary transmission. I don't see this as a strange question with that thought in mind.
FRC http://www.frc1266.com/
Battlebots http://www.mutantrobots.com/
