Go to Post The only fee our team charges is for your heart and soul. No refunds. - Koko Ed [more]
Unread 09-02-2013, 20:26
cdizzle cdizzle is offline
FRC #2367
cdizzle is an unknown quantity at this point
Window Motor Problem?
Hi everybody,
Our team is trying to use a window motor on our robot using LabView, but when we program the motor to turn clockwise with one button and counterclockwise with another button, the motor spins perfectly counter clockwise. When we try to spin it clockwise, the motor twitches instead of moving smoothly.
At first we thought it was a jaguar problem, so we replaced it with a victor, but it still has the same problem.
Any thoughts on why?
Thanks,
-Team #2367
Unread 09-02-2013, 20:41
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
Re: Window Motor Problem?
did you use the invert function or did you set a constant to -1? If you used the constant change it to the invert function.
the function is located in the programing pallet under numeric.
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
Unread 09-02-2013, 21:08
FRC #2367
I don't think that's the problem, because we ran both of them counterclockwise (positive), and the motor still ran twitchy when we pressed one button and clean when we pressed the other
Unread 09-02-2013, 21:17
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Did you try running it right off a battery in both directions and try an identical motor in your setup? It may be a bad motor/gearbox.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
You may want to look into this.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 09-02-2013, 21:22
FRC #2367
We tried that, and it runs smoothly in both directions.
Unread 09-02-2013, 21:25
FRC #2367
We tried running it with a standard CIM motor, and we still had the same problems, so I don't think it has anything to do with the locking pins on the window motor.
Unread 09-02-2013, 22:51
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Can you post a screen shot of you code that is switch the motor from one direction to the other? This sounds like you might accidentally be sending the motor both a forward command and a reverse command. That can result in your speed controller randomly switch from forward to reverse at high speed, thus resulting in your motor twitching.
You beat me to the punch with testing with a CIM. Good job. That definitely isolates it to a programming or electrical problem.
FRC #2367
It seems like a coding problem, but I can't figure out what the problem is at all. We tried both a Victor and a Jaguar, so I don't think that is the problem. The code is very standard, I just wired two buttons to a case block. And for one of them, I ran the motor forward when it was true, and backward when it was false. The motor itself is upside down, so it doesn't work properly when the motor is turning forward, but it works well in reverse.
Unread 09-02-2013, 22:57
I'm having difficulty parsing what you're doing. You've wired two buttons to one case block? Are you having one button that turns the motor on/off and the second one that picks the direction? I think it'd be a lot clearer if you posted the VI or a screenshot of it.
Unread 10-02-2013, 00:29
FRC #2367
I'm really sorry, but my code's all at the lab, so this is the best that can do for now, but I'll try to explain it as well as I can.
I have 2 case blocks. One case block is wired to button 3 on our joystick. When that case is true, it sets the motor speed to -0.9. That one works smoothly. I also have another case block which is wired to button 4 on our joystick. When that case is true, it sets the motor speed to 0.9. When I press that button, the motor moves in the right direction, but it stops and jerks forward and then stops again. Note that I haven't put anything in the false part of the case blocks.
Thanks so much for your help and once again I'm really sorry that I can't post a screen shot right now.
Unread 10-02-2013, 01:29
That's certainly a recipe for weirdness if you're pressing both buttons at once. Also, how on earth does your motor stop after you let go of a button? If you let go of the counter clockwise button, does the motor stop or keep going? If your motor stops then you're clearly setting the motor speed to 0 somewhere else, since it's not in your false cases. If you're setting speed to 0 elsewhere, then your button 3 code is beating out the zero speed code and keeping things moving. Your button 4 code occasionally loses to the zero speed code and thus sometimes the motor stops, and sometimes it moves. Assuming you're setting speed to 0 somewhere.
What I like to do for programming two buttons to turn a motor is to pick a dominant case. That means that you pick one of the buttons that "wins" if both buttons are pressed. Then you can pretty easily use two Select blocks to set the motor speed. See my attached code snippet, in which button 3 "wins" and gets final say in the motor speed.
Name:	Motor Snippet.png
Unread 10-02-2013, 02:10
nicholsjj's Avatar
AKA: John Nichols
You could try switching imput buttons on your joystick to see if that helps also. I know our gamepads had a glitchy button on it. You might want to put the -1 value and then invert that into you motor output to see if it works also.
Unread 10-02-2013, 02:15
FRC #2367
Wait, so if I set my motor speed to 0 when false in the case block for button 3, will it affect the motor when the button 4 case block is true?
Yeah, we tried both of those things, and neither worked.
Unread 10-02-2013, 02:36
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
What I've always done is just put the numbers in the case statements, with the Set VI outside the case. The true cases have the values to set the motor to, and the false cases both have 0 in it. Just to the right of the case, I put an addition operator in. That way, if one button is pressed, it adds 0, not affecting the output. 0+0 = 0, x+0 = x, and x+y=0. (Of course, this only works when both positive and negative values are the same...)
Edit: I also use the Select statement for the values, not just cases. Keep forgetting I usually put global sets in there too.
I'm right 90% of the time, so why worry about the other 3%?
