Go to Post Once you have reached overkill, more is not useful. - DonRotolo [more]
Unread 10-02-2013, 02:51
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
Re: Window Motor Problem?
[quote=cdizzle;1230855]Wait, so if I set my motor speed to 0 when false in the case block for button 3, will it affect the motor when the button 4 case block is true?
No it should just affect the output from case three. My next question is are you sending both button outputs into the same motor set output vi. This might be where Kevin's statement about overriding can occur if you use two different vi's.
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
Unread 10-02-2013, 09:31
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
If you have two completely separate case blocks for button 3 and 4, then yes, the false case in the button 3 block will affect button 4 even if button 4 is true. See my attached snippet. The top two show the cases in the case blocks. The bottom shows what will run when button 3 is false and button 4 is true. Both of those case blocks will run, which means you're trying to set the motor speed to 0 and set the motor speed to 0.9 at the same time. The results of trying to set the motor to two different speeds simultaneously are not particularly predictable.
Cecil's suggestion of putting the motor set block outside of the cases is also a good one. Then you know that you only have one motor set and it's only going to run once. Then you just have to figure out how to send it the appropriate value. It makes it pretty obvious if your value selection method isn't valid because you'll end up trying to wire two thing to the same input, which labview will complain about.
Name:	Bad Motor Snippet.png
Unread 10-02-2013, 19:50
cdizzle cdizzle is offline
FRC #2367
cdizzle is an unknown quantity at this point
I got it working! Thanks for your help guys! I think something was overriding the reverse command, but I couldn't figure out what it was, so I just wired it to one SetMotorSpeed like you guys said to.
Unread 10-02-2013, 20:26
Just as long as you remember this and apply that design pattern to the rest of your systems so you don't have the same problem in the future.
