Go to Post Just remember to never take the "Us vs Them" mentality and you should come out all right. - Ian Curtis [more]
Unread 10-02-2013, 04:51
anthonyR anthonyR is offline
FRC #1661
anthonyR is an unknown quantity at this point
LabVIEW coding error: Unable to run the robot.
I am the programmer for Team 1661. We am having an issue with either the code or the electronics: whenever we try to run just the simple code that FRC gives us we get a 44002 and a 44003 error saying that the driver station cant run the robot code and saying that the ping results are bad. We are using 4 motor talon drive and I have changed the code accordingly. Also I know for sure that the PWM's are all connected to the correct location. Whenever we run the code the talons receive voltage and the PWM's are sending out 5 volts but no motors move. Yes I understand the the ping warning is just saying that we aren't connecting with ethernet and are connecting to the radio with wifi but it still confuses me. So basically is the problem just the Talons' fault or is something actually wrong with the code?
Unread 10-02-2013, 07:01
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Re: LabVIEW coding error: Unable to run the robot.
can you run any of the other examples on this cRIO?
did you fix the 10.xx.yy.2 address in the LabVIEW project you are running?
Unread 10-02-2013, 08:20
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Before you do anything with the code, turn the robot on and open the driver station.
What are the driver station diagnostic lights telling you? Does the lower left say "no code", "teleoperated disabled" or something else?
Have you put in your team number in the setup tab?
Unread 10-02-2013, 14:57
FRC #1661
It says no code as I have re-imaged the cRIO and erased all previous code. It also says teleoperated disabled unless I run it. Also the basics for the code are correct. It says 10.16.61.2 for the cRIO and all the communications are in check it just will not run.
Unread 10-02-2013, 19:08
Originally Posted by anthonyR View Post
...we get a 44002 and a 44003 error saying that the driver station cant run the robot code and saying that the ping results are bad.
Read that 44002 message again. It's a "warning", not an "error". It also contains many individual bits of information, telling you basically what devices the Driver Station is able to detect on the network. The only ones you should care about are the "Robot Radio(.1)" and "cRIO(.2)". If those are GOOD, you're fine. Don't worry about any of the others. You'll always see FMS as bad until you're actually connected to a competition field, for example.
Unread 11-02-2013, 00:20
FRC #1661
So does that mean there is something wrong with the program then. I am using the code supplied to us by FIRST so I would expect not but what else could it be?
Unread 11-02-2013, 00:41
It could be any of a hundred things.
Tell us what your robot and Driver Station are telling you. They have a lot of blinky lights of various colors that give a lot of information about what is going on. For now, focus on the Driver Station "Communication" and "Robot Code" indicators, the big orange Robot Signal Light, and the LEDs on the Talon speed controllers. What are they all showing 1) when the robot is disabled, 2) when it is enabled, and 3) when you try to move the motors?
