Go to Post My students like to win, so I'll stick to enabling that. - sdcantrell56 [more]
Unread 06-02-2013, 16:05
ohhs4284 ohhs4284 is offline
FRC #4284
ohhs4284 is an unknown quantity at this point
Exclamation When deploying code in NetBeans it hangs.
When we deploy our code in netbeans we go through the normal upload process until it gets to this.
[cRIO] edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@8 entered connection state: GOT_CONNECTION_FROM_CLIENT
[cRIO] edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@8 entered connection state: CONNECTED_TO_CLIENT
From here it just hangs and never completes. We have flashed the Crio multiple times and re-installed netbeans and the plugins.
Unread 06-02-2013, 16:10
FRC #4284
Re: When deploying code in NetBeans it hangs.
On a side note we have ended the build in netbeans and have both green lights on communication and robotcode but the jags blink and nothing else seems to work.
Unread 06-02-2013, 16:32
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Does it not enable?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 06-02-2013, 16:36
FRC #4284
I can enable but the jags blink yellow.
Unread 07-02-2013, 15:42
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
thats the final stage of the deployment process, its finished, you initialized the jags in the wrong PWM slot in the code
Unread 09-02-2013, 14:41
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
we have the same problem, either you initialized the jags in the wrong PWM slot in the code, as Arhowk said but most of the time the problem is that you wired the PWM cables wrong. What we do is flip the PWM cables and it works because up till now our electrical team (including me) dont know which way the cables go (black on the inside or outside......no idea).
Hope it helped
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 09-02-2013, 16:52
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Hope it helped
From my experience, if PWM cables are backwards than the robot will go forwards instead of backwards than stall instead of going forwards
Unread 10-02-2013, 08:05
2185Bilal's Avatar
AKA: Bilal Majeed
I am pretty sure you are mistaken sir, not to be mean at all. When the pwm cables are wired backwards the signal wire plugs into the ground slot while the ground slot goes to signal wire. So there is no possible that this mistake would make the robot go in the opposite way.
However, i think u might be talking about switching the wires from the motors to the jaguar. Meaning that u switch the arrangement so that positive goes in the negative place. When this is done u are right it makes the motors go in the opposite way.
RAMAZOIDZ
Unread 10-02-2013, 12:11
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Yeah, i was referring to the PWM cables being backwards.
Unread 10-02-2013, 19:46
2185Bilal's Avatar
AKA: Bilal Majeed
they are not called pwm cables, wiring them backwards would basically not make the robot run, hence the blinking lights
RAMAZOIDZ
