Go to Post If you can spare 2 minutes (And I know you can, because the season’s over and you’re STILL on Chief Delphi) - LVMastery [more]
Unread 10-02-2013, 12:19
rhp3794 rhp3794 is offline
rhp3794 is an unknown quantity at this point
Axis camera m1011 help!!!
Hi!
Our main problem is that the axis camera set up app cant read the axis camera when i connect the pc to the camera.
After that i dont know how to set it to the robot radio or maybe the c-8CRio slot
please help it is very important for us.
Thank you.
Programming Leader
Team 3794
WinT
Unread 10-02-2013, 14:10
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Re: Axis camera m1011 help!!!
To set it up, first set your computer's wired connection address to 192.168.0.11
Then, open up the "Setup Axis Camera" tool and type in your team's number in the lower left corner and select which option you want, Radio or 8-slot cRIO, (I would recommend Radio). And hit the button in the lower right corner. The tool should set it up for you, and then your camera will work when it is connected to your Radio.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 10-02-2013, 14:29
Ok! thank you, after that i realized that the camera needed to be restarted because a week ago i tried to configured it by myself and i screewed the IP adress thanks a lot!
Programming Leader
Team 3794
WinT
