Go to Post A lack of knowledge is okay; a lack of initiative to learn more is not. - Madison [more]
Unread 09-02-2013, 11:31
Gadeer Zbedat Gadeer Zbedat is offline
FRC #1946 (Mishka Monster)
Gadeer Zbedat is an unknown quantity at this point
Robot code does not work
when we try to download our code to the crio
!!! it download successfully ... !!
but the Robot Code green light in the drive station doesn't appear.. !!
We did new imaging to the crio !! !! but it does't work !!!
we want to define the crio to the windriver ..
our code is correct without any error's . ...
so what should I do guys ?!!!
please help me ( FIRST Spirit ) <3 ::*:
Unread 09-02-2013, 12:34
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Re: Robot code does not work
We had the same issue earlier this year. Try commenting out newer parts of your code to see where the issue is. The error in the code may still let it compile but must be removed to allow code to run on the cRio.
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 10-02-2013, 12:47
Enable NetConsole output and look at the cRIO's messages when it starts up. There is likely to be a runtime link error displayed about a missing function or other symbol. If you can't figure out what it's telling you, post the output here and someone will probably be able to interpret it for you.
