Go to Post I need someone to kick me out...unfortunately that would have to be me... - Mark McLeod [more]
Unread 10-02-2013, 12:57
Re: how to program shooter on LabVIEW
If you really do want both of the shooter motors to run as a single unit, you can use a "2 motor Drive" for them. But when you save the RefNum, you should give it a name that describes what it is. The "Left and Right Motors" RefNum name is already being used to set the actual drive motors. Make it "Shooter Motors" instead.
But I would open them as two separate motors instead of a "Drive" pair. If I wanted them to always run at the same speed, I would actually open them as a single motor and use a PWM Y cable to send one control signal to two speed controllers at the same time.
