Go to Post Honestly I'm looking forward to just seeing all my friends again, that's what FIRST is really about to me. - Barry Bonzack [more]
Unread 10-02-2013, 14:53
Mr.Roboto3335's Avatar
Mr.Roboto3335 Mr.Roboto3335 is offline
Wait, What?
AKA: Jimmy
FRC #3335 (Cy-Borgs)
Mr.Roboto3335 is an unknown quantity at this point
Pressure switch
We are using a pressure switch to turn on/off the compressor. I've been searching the interent with no luck in finding anything useful. If you can help it would be appreciated.
Wait, what?
Unread 10-02-2013, 15:07
GreyHat GreyHat is offline
FRC #0087
GreyHat is an unknown quantity at this point
Re: Pressure switch
What exactly is the problem you are experiencing? You're extremely vague about what you're asking.
Unread 10-02-2013, 15:11
Wait, What?
AKA: Jimmy
Re: Pressure switch
I just want to learn how to program a pressure switch to turn on the compressor when the pressure gets lower than 90psi and turn off at 120.
Wait, what?
Unread 10-02-2013, 15:15
FRC #0087
Re: Pressure switch
Run a periodic check on your Pressure Switch class to check if the value is less than 90 PSI, and if the compressor is not already on. If it isn't, turn it on. Then do another check to see if pressure is greater than 120 PSI, and if the compressor is on. If it is, turn it off.
Unread 10-02-2013, 15:19
Wait, What?
AKA: Jimmy
Re: Pressure switch
I just started learning java so I have no idea how to put that into code.
Wait, what?
Unread 10-02-2013, 15:52
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Pressure switch
There is a method in the WPLIB? for the compressor. It should run in one of the periodic sections of code. The pressure switch is one of the digital inputs which the method reads & turns on & off the spike on one of the digital outputs. I believe you pass the IO you are using. Sorry for vagueness, I have minions that do actual programing.
Unread 10-02-2013, 15:57
Wait, What?
AKA: Jimmy
Re: Pressure switch
I still don't understand. Can you put that in actual code?
Wait, what?
Unread 12-02-2013, 11:07
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Pressure switch
Take a look at this web page. It shows how to use the Compressor object built into WPILib. It will automatically run the compressor when the pressure switch shows low pressure.
Be sure to not put the code in a loop since the Compressor class will start up a thread that will do all the checking in the background.
http://wpilib.screenstepslive.com/s/...for-pneumatics
Brad
Brad Miller
Robotics Resource Center
