Go to Post I emailed Brandon Martus to have my username changed. It was updated within a day. Champion webmaster at work. - Gregor [more]
Unread 10-02-2013, 16:56
y-aji y-aji is offline
FRC #3734
y-aji is an unknown quantity at this point
pg71 || spike h-bridge or talon?
Can you use either or is the talon illegal as I've seen in other areas? I assume 14awg is fine with a 20 amp relay. Does that sound right? I see it peaks at 22, this wont have any load on it.
Unread 10-02-2013, 17:01
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Re: pg71 || spike h-bridge or talon?
Depends on what you want to do with it. I assume by PG-71 you mean the AndyMark 0912 motor (colloquially referred to as a AM Gearmotor). As per Rule R52, you can run the motor on either a Talon or a Spike. However, if you want to have any sort of control over the motor I would suggest a Talon, as a Spike is purely a relay with the ability to either turn the motor on or turn the motor off.
Academic Student (Forever)
Unread 10-02-2013, 17:02
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Check out R52.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 10-02-2013, 17:25
FRC #3734
Thank you much!
