Go to Post Antimatter.. It will help us in the never ending quest to build the bot under the weight limit. - Elgin Clock [more]
Unread 06-02-2013, 21:17
wickzam wickzam is offline
FRC #4591
wickzam is an unknown quantity at this point
Help programming joystick buttons
Hello we are team number 4591 we are a rookie team. Our programming team consists of 2 people and we have just started programming a few months ago.
We have sucessfully made our robot move forward and backwards using two joysticks.
We need to move two motors at the same time while holding one button to go clockwise and holding another button to go counter clockwise.
We have tried everything we know, but nothing seemed to work. It would be very helpful if someone could give us an example of a code we can use to run the motors.
Here's what we have so far:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.buttons.Button;
public class RobotTemplate extends SimpleRobot{
      RobotDrive chassis= new RobotDrive(1, 2);
      Joystick leftStick= new Joystick(1);
      Joystick rightStick= new Joystick(2);
public void autonomus() {
      chassis.setSafetyEnabled(false);
      chassis.drive(-0.05, 0.0);
      Timer.delay(30.0);
      chassis.drive(0.0, 0.0);
      public void operatorControl() {
      chassis.setSafetyEnabled(true);  {
            chassis.tankDrive(leftStick, rightStick);
            Timer.delay(0.01);
Unread 07-02-2013, 16:30
The_Colonel The_Colonel is offline
FRC #4456
The_Colonel is an unknown quantity at this point
Re: Help programming joystick buttons
There is a function called getButton() that allows you to use the trigger and top button, and one called getRawButton() that works for the rest of the buttons by number. This page should help you get a complete understanding of the joystick, the buttons, and the rest of the code for the robot.
http://www.wbrobotics.com/javadoc/ed...ge_description
Unread 07-02-2013, 17:13
You can use the getRawButton method of the joystick class to get whether a button is being pressed or not.
Unread 07-02-2013, 18:09
FRC #4591
We tried to use getRawButton in our code but every time we use it there is a problem.
if you could show us an example of a code using getRawButton that would be very helpful.
Unread 07-02-2013, 18:32
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
i dont get it. whats your problem
Joystick j = new Joystick(1);
JoystickButton a = new JoystickButton(j,1);
a.whileHeld(new YourCommand());
in command based or
if(j.getRawButton(1)){
do stuff
in iterative. both will run when A is pressed
Unread 07-02-2013, 18:38
What kind of problem?
Here is an example of using getRawButton to switch between tank drive and arcade drive when the trigger (button one) on the left joystick is pressed.
        if (leftStick.getRawButton(1))
            Timer.delay(0.01);
        else
            chassis.arcadeDrive(leftStick);
Also, in your original code, your autonomous code won't run because autonomous is misspelled.
Unread 11-02-2013, 02:06
arithehun arithehun is offline
AKA: Ari Falkner
FRC #3024
arithehun is an unknown quantity at this point
Have you heard about command based programming? It is a lot cleaner and will help you avoid creating hundreds (okay, not hundreds) of "else if" blocks and actually set up a polymorphic structure and abstracting your code. It's a specifically tailored design pattern. It's probably too late now, but it's something you should consider next year: http://firstforge.wpi.edu/sf/docman/...tation/doc1297
Unread 12-02-2013, 13:01
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
            Timer.delay(0.01);
A quick aside:
Because you are using SimpleRobot you need to put the teleop code in a loop, e.g.:
         while (isOperatorControl && isEnabled() ){
            Timer.delay(0.01);
The above suggestions for button use are all good, so if they aren't working this might be part of the problem. If you just typed from memory and forgot, ignore this. You also had a superfluous set of braces after you SafetyEnabled, did you accidentally delete something?
Just noticed you have a 30s delay in autonomous. Autonomous mode is only 15s. Unless something changed this year operatorControl() won't be called until autonomous() exits. So you'll be waiting 15s after teleop starts to get control of the 'bot.
