Go to Post ...FIRST was created to change that world for the better. To presume that FIRST is simply here for your enjoyment is to demote it to nothing more than an expensive game... - RogerR [more]
Unread 11-02-2013, 13:55
chrissevigey chrissevigey is offline
FRC #3411
chrissevigey is an unknown quantity at this point
Exclamation 4 motor drive problems
When running a 4 motor drive on the robot, everything is working, except when I turn full left, the rear left side jaguar stops, then all the motor controls stop, and I have to disable and re-enable the driver station to get any movement again. Does anybody know what's going on?
Unread 11-02-2013, 14:05
Re: 4 motor drive problems
I can almost guarantee that you've failed to provide 12 volt battery power to the Digital Sidecar.
Unread 11-02-2013, 14:11
Team3763 Adam Team3763 Adam is offline
Lead Programmer
FRC #3763 (4H WildCards)
Team3763 Adam can only hope to improve
This is more than likely the problem. My team had the same problem a few days ago. To fix it, run wires from the PD board, with a 20A fuse, into the WAGO connector on the Digital Sidecar. This will give you your Bat, 5V, and 6V Green LED signal lights.
Unread 11-02-2013, 18:40
FRC #3411
Thanks so much. That took care of it!
