Go to Post Equally possible is that we're just providing some lunch-break entertainment for the people in the GDC. - wasayanwer97 [more]
Unread 11-02-2013, 13:55
chrissevigey chrissevigey is offline
FRC #3411
chrissevigey is an unknown quantity at this point
Exclamation 4 motor drive problems
When running a 4 motor drive on the robot, everything is working, except when I turn full left, the rear left side jaguar stops, then all the motor controls stop, and I have to disable and re-enable the driver station to get any movement again. Does anybody know what's going on?
Unread 11-02-2013, 14:05
Re: 4 motor drive problems
I can almost guarantee that you've failed to provide 12 volt battery power to the Digital Sidecar.
Unread 11-02-2013, 14:11
Team3763 Adam Team3763 Adam is offline
Lead Programmer
FRC #3763 (4H WildCards)
Team3763 Adam can only hope to improve
This is more than likely the problem. My team had the same problem a few days ago. To fix it, run wires from the PD board, with a 20A fuse, into the WAGO connector on the Digital Sidecar. This will give you your Bat, 5V, and 6V Green LED signal lights.
Unread 11-02-2013, 18:40
FRC #3411
Thanks so much. That took care of it!
