Go to Post i have a feeling that the field with be the same as it was last year just to save some money. but what is inside the the field will be diferent. - Michael Leicht [more]
Unread 11-02-2013, 14:07
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Re: rule against tape
Depends on what it's used for. Typicallly, tape can't be used structurally (i.e. holding things together) but you can use it as a decoration. I'm assuming this is what you're asking about. What are you using it for?
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 11-02-2013, 14:12
That hasn't been a rule for years. However, there generally is a better way then using tape structurally.
Unread 11-02-2013, 14:23
Checked the manual, you are correct. Years are just blending together!
Unread 11-02-2013, 14:31
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
The aluminum foil tape I guess seems weird to me - but you cant use it as an attempt to throw off vision tracking either if that was the intent. Otherwise please ignore.
Unread 11-02-2013, 14:15
dtengineering's Avatar
AKA: Jason Brett
So, what you are really meaning to say is,
"I looked in the rule book, searched in the rule book, scoured the rule book and couldn't find a rule against tape, yet someone keeps insisting that there is a rule against using tape on the robot. Have I missed something?"
Right? That is what you've done... you haven't just posted here because you were too lazy to actually go to the rule book, and type "tape" into the search box, and see if anything came up?
There were, at one time, rules against using tape on your robot except for very specific, appropriate, applications. But I haven't seent those rules for several years now... so if you can't find something in the rule book that prevents you from using it... it's good. Even for structural applications.
But do take some time to read the rule book carefully... you may find other rules that restrict material usage and it is a LOT better to know about them now than when you get to the competition.
Jason
