Go to Post PS. Listen to the wise Brandon Martus. Think before you (re)act. - artdutra04 [more]
Unread 11-02-2013, 14:37
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Losing power through DS.
No RSL blnk and half the PWMS are out? What are you using to connect the DSC to your cRIO? If you're using a ribbon cable, that sounds like about half the ribbon cable isn't crimped properly. Try a different, known good ribbon cable and/or check your current ribbon for continuity. A good ribbon cable should have continuity pin-for-pin from the male to the female side.
Unread 11-02-2013, 16:29
Team3763 Adam Team3763 Adam is offline
Lead Programmer
FRC #3763 (4H WildCards)
Team3763 Adam can only hope to improve
We do have all three signal lights, Bat, 5V, 6V, and we are using the flat cable. We DO have the rounded cable and at today's meeting I plan on switching the flat cable to the rounded variant.
Unread 11-02-2013, 18:05
If I recall correctly, there were different weird issues with some of the round cables. I believe they centered around using the accelerometer with I2C, so that may not be a concern for you.
Unread 12-02-2013, 13:10
Lead Programmer
I heard that also, and I don't think we'll be using an accelerometer. However, a gyro, is still up in the air. We replaced the flat cable with the round cable, and used a brand new DS. All lights were good, and the RSL flashed/stayed constant when it was supposed to. We have yet to test the PWM channels, but I have high hopes that they will work.
Unread 12-02-2013, 14:13
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
I agree with the above; also check for damage and proper seating of the connector on the sidecar and digital module.
This happened to us when the cable wasn't fully seated. One end was up only about a sixteenth of an inch, not really enough to see easily, but some PWMs stopped working.
I worked with another team who had a nick in their ribbon cable and the connection would cut out randomly. That one might sneek by a continuity check so do a visual inspection under a magnifier if you have one. Look for sharp creases as well as breaks in the insulation.
Good luck!
Unread 13-02-2013, 22:58
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
If all else fails, in the previous years we've wired the light into the 12V terminal on the PD board. Could we splice the wires to the light and wires to the D-Link together and connect it to the same terminal?
You may think you wired it into the 12v terminal, but if you passed inspection, it most certainly was not. That is a very specific thing that is checked for during the power-up phase of inspection. It also is very likely to be noticed by the field personnel if not working properly.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 14-02-2013, 08:00
In rare cases I have seen a DSC with all three lights on but dim. There was no connection to 12 volts on the PD. All three lights have to be on and bright.
Unread 14-02-2013, 12:12
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
While we're on the DS, PWM channels 4-10 didn't seem to function at all, sending signal to the Jaguars it was told to. In the code, we changed the PWM to 4-10 depending on which channel we were testing. Could it be possible that ALL of these channels are blown? We've swapped PWM cables, used other channels, and tested other Jaguars to find that everything EXCEPT the PWM channels work.
I would also check the power to the DS. We had a similar problem last year.
"This must be what going insane feels like."-Simon Tam, Firefly
