Go to Post I joined because I needed something to complete my nerdyness and I never regretted it. - Regine [more]
Unread 06-02-2013, 13:54
AquaMorph's Avatar
AquaMorph AquaMorph is offline
Alumnus of 2059
AKA: Christian Colglazier
FRC #2642 (Pitt Pirates)
AquaMorph is on a distinguished road
Moving Only the Back Wheels
This year my team is having FIRST wheels in the back and omni wheels in the front. Each wheel has its own gear box and CIM. We are driving the robot with the 4 motor arcade drive. I want to program a special mode where only the back motors move. Is there a way to do this?
FRC Drive: Play Store FRC Manager: Play Store
Unread 06-02-2013, 14:15
Re: Moving Only the Back Wheels
I can think of three ways to do it. One is probably more complicated and hackish than anyone should try. One involves completely ignoring the "Drive" functions and building your own out of regular Motor VIs.
The one that I'd actually try implementing myself is something like this:
Open each drive motor separately. Pass the motors' RefNums into an Open 4 Motor Drive function that's been set to the "existing motor" variant. Pass the rear motors's RefNums into a similar Open 2 Motor Drive function. Now you can choose to invoke the Arcade Drive function of either the 4-motor or the 2-motor Drive set. You'll have to disable the safety on the one you're not actively controlling.
I'm curious -- why do you want to do this?
Unread 06-02-2013, 14:20
AquaMorph's Avatar
Alumnus of 2059
Yeah I was think something along the lines of your third idea. We would like to do this to give our robot a better fine turning ability for aiming.
Unread 11-02-2013, 14:38
How did that work out for you? Did you actually get better fine turning ability with only 2 wheels powered?
Unread 15-02-2013, 12:30
AquaMorph's Avatar
Alumnus of 2059
I tried the last method and now the robot will not drive at all. I guess the normal four wheel drive will have to do.
Unread 15-02-2013, 22:27
DonRotolo's Avatar
Back to humble
FRC #0832
Giving up that easily?
Unread 16-02-2013, 09:07
AquaMorph's Avatar
Alumnus of 2059
Well I have more important things I have to program.
