Go to Post We can't be afraid to critique the existing system. If we don't, how will it ever get better? - Jaine Perotti [more]
  #31   Spotlight this post!
Unread 11-02-2013, 13:49
Bunniy's Avatar
Bunniy Bunniy is offline
The Only Programmer
FRC #3337 (Panthrobotics)
Bunniy is an unknown quantity at this point
Re: Photosensor as encoder for bang bang.
And can you also check my global variable
Think Outside The Frame
  #32   Spotlight this post!
Unread 11-02-2013, 13:50
Bunniy's Avatar
The Only Programmer
The DSC is?
  #33   Spotlight this post!
Unread 11-02-2013, 13:57
Originally Posted by Bunniy View Post
The DSC is?
It's the blue thingy where you wire all your DIO.
  #34   Spotlight this post!
Unread 11-02-2013, 13:59
Bunniy's Avatar
The Only Programmer
Haha is it the digital side cart i should wire the Photosensor to or the blue thingy on the crio
  #35   Spotlight this post!
Unread 11-02-2013, 14:05
That's why we avoid using words like "thingy" in this forum.
You want to wire your sensor to a DIO on the Digital Side Car.
  #36   Spotlight this post!
Unread 11-02-2013, 14:11
Bunniy's Avatar
The Only Programmer
haha thank you. I will try it.
  #37   Spotlight this post!
Unread 11-02-2013, 14:13
Just a caveat about the Photosensor.
What model are you using?
If it's this Kit one:
Then the power wiring gets a bit unusual.
The signal connects to the Digital Sidecar, but it can be unwise to take power for this particular sensor from there.
It doesn't handle voltage dips well.
We can describe what to do, but I don't want to clutter the thread if you're using some other model.
P.S.
I'll take a look at your revision Bill. I just have had only snippets of time over the past couple of days.
I know a lot of new names for snow now, but not in polite company...
  #38   Spotlight this post!
Unread 11-02-2013, 14:19
Bunniy's Avatar
The Only Programmer
Yes i am using that kind. I have it powered by the power distribution board
  #39   Spotlight this post!
Unread 11-02-2013, 14:30
Bunniy's Avatar
The Only Programmer
I used what you gave me and now my motor wont even spin at all
  #40   Spotlight this post!
Unread 11-02-2013, 14:48
He appears to be talking to you, Mr Bill. His post is linked here:
http://www.chiefdelphi.com/forums/sh...6&postcount=22
  #41   Spotlight this post!
Unread 11-02-2013, 14:49
Bunniy's Avatar
The Only Programmer
I fixed the spinning part. I wired it wrong. But still the motor is still spinning as fast as possible
  #42   Spotlight this post!
Unread 11-02-2013, 14:50
Bunniy's Avatar
The Only Programmer
It is still making my motor spin as fast as possible
  #43   Spotlight this post!
Unread 11-02-2013, 15:10
The problem with this particular sensor is that it's minimum voltage spec. is 10.8v.
With a fresh battery and early in a match without pushing contests and not a lot of motors powered all at once, that's probably fine.
The danger is when the robot battery voltage drops below 10.8v (because it's towards the end of a match full of pushing defensive robots or the battery gives out early) the feedback from the sensor can become random. It won 't count correctly.
There is an alternate source of guaranteed stable power if you are using a 24v Solenoid Breakout. The sensor can be wired just to an available power pin.
  #44   Spotlight this post!
Unread 11-02-2013, 15:14
Bunniy's Avatar
The Only Programmer
can you show or tell me where or what that is that i have to wire it to
  #45   Spotlight this post!
Unread 11-02-2013, 15:31
For now I'd leave it where it is until you get the code figured out and working correctly.
Are you using solenoids this year?
If you are, then are you using 24v solenoid came in the Kit the past couple of years. This year they were offered in FIRST Choice.
