Go to Post Competing at multiple regionals or Championship events has no bearing on the life lessons you will learn or the unbelievable memories you will have--for that is what FIRST is truly all about. - Alivia [more]
Unread 11-02-2013, 16:25
y-aji y-aji is offline
FRC #3734
y-aji is an unknown quantity at this point
Talon not responding
I think we have everything set up for the Talons. Can someone confirm that the following is correct?
I have tested the motor as good. The Talon sits blinking orange, never confirming it is receiving signal from PWM.
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Talon;
public class AwesomOSimple extends SimpleRobot {
    Talon frisbeeIndexer;
    public void robotInit() {
        frisbeeIndexer = new Talon(9);
    public void operatorControl() {
        frisbeeIndexer.set(1.0);
Is there more needed than that? I feel like you have to enable it. I see there is an option to disable it (frisbeeIndexer.disable()). I've tried 0.9 and a simple 1, but nothing. Any thoughts?
I'm going to check that no one plugged something in backwards tonight, so that's still up in the air, I just wanted to cover the software.
Unread 11-02-2013, 18:19
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Talon not responding
operatorControl() is only called once. If you want to actually do something, you have to make a loop.
public void tele()
//Don't modify the following method
 while (isOperatorControl())
    tele();
    Timer.delay(3/1000); //this prevents the cRIO from becoming overloaded, especially if tele() is empty
Having tele() as a separate method keeps things clearer and keeps inexperienced programmers from messing with something they shouldn't, but you're more than welcome to have everything in operatorControl().
Unread 11-02-2013, 19:51
FRC #3734
Sigh.. Someone plugged in the Talon backwards. Lol. I had to restart the whole robot after the Talon was plugged in correctly to get it to respond happily. The minute I turned it around, it worked fine.
If you query my username, I think every question I have asked has been answered this way for the past 3 years.. Haha..
Thank you!
