Go to Post Looks like I'm late, but in the grand tradition of Chief Delphi, I'll butt in and beat the dead horse anyway! - PayneTrain [more]
Unread 11-02-2013, 18:13
JCrusoe JCrusoe is offline
Jacque Crusoe
FRC #3880 (Tiki Techs)
JCrusoe is an unknown quantity at this point
Smile Re: Programming Shooter C++
Without your current code its hard to tell what the issue is, but I would make sure that you have it in the constructor correctly. I'm going guess that its a Jaguar, but it could easily be a Victor as well.
#include "WPILib.h"
class RobotDemo : public SimpleRobot
	Jaguar shooter;
	Joystick driveStick; //it can be any name, not strictly driveStick :)
public:
	RobotDemo(void):
		//JAGUARS//
		shooter(1),	    //This is what port your shooter motor is in on the Sidecar
		//JOYSTICKS//	// These must be initialized in the same order
		driveStick(1)	// as they are declared above.
		shooter.SetExpiration(0.1);  //for Driver Station
	void Autonomous(void)
			//where your autonomous would go
	void OperatorControl(void)	//The Operator Control, what you're looking for!
		while (IsOperatorControl())
			if(driveStick.GetRawButton(2)) //This is a structure that says if 2 is pressed, shooter
			{							   //will be set to 100%
				shooter.Set(1.0);
			else                           //anytime when it isn't pressed (else), the shooter will turn
			{							   // off
				shooter.Set(0.0);
			Wait(0.005);  // wait for a motor update time
	void Test()
		//what runs during test mode
START_ROBOT_CLASS(RobotDemo);
