Go to Post Hmmm, the Michelangelo method of robot building. Just cut away anything that doesn't look like a robot. - GaryVoshol [more]
Unread 11-02-2013, 21:12
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Can you help us get our robot unstuck?
We designed our robot to climb from one rung to another by attaching with an arm and then flipping over to attach with another arm. It works but only if we help it detach the lower arm after it flips. All the weight is on the lower arm and it can't let go of the rung to move on. This is a video of the robot climbing (but the human assistance in getting the arm detached isn't shown), http://www.youtube.com/watch?v=cgbJ7...ature=youtu.be. We can't figure out how to correct this problem. We thought of hinging the arm but that probably won't do it. Any ideas?
Unread 11-02-2013, 21:44
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Re: Can you help us get our robot unstuck?
Not sure but it looks like you would be exceeding the 54in rule.
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 11-02-2013, 21:46
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
That's certainly an exciting way to climb. If you guys pull that off I think it means I lose a bet with a former student. In furtherance of this:
1. Are you guys sure you're making a valid climb? It looks like you come awfully close to touching the second level while you're still touching the floor.
2. Remember you'll be doing this from across the playing field. Lining up and making those motions may be challenging.
You've definitely discovered the downside of using gravity and leverage to grab something. How hard is it to release that bottom claw? Could you maybe attach a short stroke 2" bore pneumatic cylinder underneath the arm to shove against the pyramid diagonal and push the bottom claw away? A 2" bore has 180 lbs of push at 60psi. Or a 2.5" bore cylinder with 300 lbs of push. Bimba will sell you a 2.5" bore, 3" stroke cylinder for $90 each and ship it the same day.
Unread 11-02-2013, 21:51
Once you're touching the pyramid, you're legal if you can fit in a 54" cylinder that's 84" tall, in any orientation. And you stay within 54" of the base of the pyramid. The latter is the the only thing they're in danger of. I think they can solve that by tilting the base vertical sooner, before that claw is fully engaged with the tower. It might require some frame adjustments so the wheels are still on the ground and they can still back away in a controlled fashion, though.
Unread 11-02-2013, 22:36
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
There may just be a sweet spot where the tension on the lower grab comes off. Are you planning any position sensors on the arms so the program can move to preset positions?
Very impressive looking climber. I hope you work out the remaining issues.
Unread 11-02-2013, 23:18
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
From the video it looks like when you engage the second level the weight stays on the first level. This will probably always be true unless the distance between the two grippers is slightly less than the distance between the two bars. The grippers would then need slight tappers (or a lead in surface) to help transfer the weight to the upper gripper as it slid into position. I hope that makes sense. Basically a ramp to insure the weight ended up on the new grip point.
However any method of automatically transferring the load between grip points will be very tricky. Since the only holding force seems to be gravity and you are in the process of switching between hold points while your weight is cantilevered you have a significant risk of falling. I think you may need a solenoid driven locking pin on the grippers to prevent letting go two early. That coupled with a lead in and closer spaced grippers might do it. Or having another way to transfer the weight might work, such as some way to expand and contract the distance between the pivot points.
Whatever you do this is already a very unique way to climb. It will be great to see it in competition if you work the bugs out.
This is the zeroth day of the rest of your life.
Unread 12-02-2013, 07:02
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
It is an impressive robot. However, as other posters have asked, I'm wondering if it fits in the 54" cylinder with the bumpers mounted.
However, that's not what was asked. To detach the lower arm, your could grab the pyramid leg and give a little push. Alternatively, could you modify your gripper design to add a flange in the vertical direction so that it wraps behind the horizontal poles to take the load?
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 12-02-2013, 10:55
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
I love the design of flipping end over end and will to try and suggest a possible answer that may or may not work is, using the video as a reference.
It may be possible to rotate the robot frame CW around the upper arm and at the same time rotate the lower arm CCW. This will have to done with great care so that as the load is changed from the lower to upper arm you robot doesn't just lose it's grip and fall off
Aside the 54 " possible problem you need to watch out for differences in height from one rung to the next which according to rules may be up to 1/4 inch but I would allow for at least 3 inches either way.
Unread 12-02-2013, 11:36
tsaksa's Avatar
Yes, I agree that this is what probably needs to be done, but if you study the contact points you will see that it may not currently be possible. Trying to rotate the robot frame CW around the upper arm will tend to push the robot frame down. And trying to rotate the lower arm CCW will tend to push the robot frame up. Both are not possible at the same time, and I think this is what ends up jamming the robot in place when it tries to change grips.
The design may need either an additional joint in one of the arms, or some ability to slide one of the pivot points a bit to allow this transfer to proceed smoothly. As it is, there may not be enough degrees of freedom in the system to allow the correct motion that can transfer the weight properly.
Unread 12-02-2013, 11:38
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
It seems like there should be a "sweet spot" where it should release. You jut have to keep testing to find it, but you might consider opening up the grabber/hook part so that it is a little looser. This could be dangerous but might be enough to free it.
An alternative to the piston (If I were on your team, I would rather not add pneumatics for just one thing if you can do it with a motor) would be using a smaller motor (BAG or Bane Bots w/gearbox) and a cam/eccentric wheel to push away from the pyramid corner as you lift the bottom claw/gripper.
Regardless of how you end up doing it, you should definitely program the climb to be autonomous. If you find a sweet spot, it would be completely necessary to automise the climb.
