Go to Post CD, you are crazy!!! - Tottanka [more]
Unread 11-02-2013, 23:03
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
pic: 1306 Pyramid Test
Unread 11-02-2013, 23:05
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: pic: 1306 Pyramid Test
Do you have clearance for the top of the pyramid? The corners go vertical right above the 3rd rung for about a foot to the pyramid goal. Since you're only on level 2 here, it's hard to tell, but you might run into the pyramid goal. Just something to check...
Unread 12-02-2013, 00:52
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
Another 30pt climbing robot at Wisconsin?! I am excited to see this design in action at your test run on Saturday.
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 12-02-2013, 10:32
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
That is sure a nice 20 point climb.
Will you be able to get to the 30 pointer?
Unread 12-02-2013, 10:55
Chris is me's Avatar
AKA: Pinecone
This was one of the final hurdles with our design that we ended up abandoning. Just another infuriating wrench in the corner climb strategy.
Unread 12-02-2013, 11:42
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
80/20(T-slot) has great modularity but is heavy. I love seeing it, but I'm curious as to what size it is and how much it weighs. Our robot is about 70 pounds, a huge record for us.
Unread 12-02-2013, 12:10
cgmv123's Avatar
AKA: Max Vrany
We can definitely get 10, we should be able to get 20 and 30 points and dumping in the top is TBD.
We look forward to having you! Hopefully, we'll have a 50 point climber/dumper too.
As said above, 20 looks good, 30 is TBD.
~95 lbs frame + 11 lbs electronics (not mounted in picture) = 106 lbs
Size is around 29" (side to side) * 26" (back to front) * 39" (height)
Unread 12-02-2013, 13:11
I wish we had a 50pt dumper - we are going with an instant 10pt hanging design. I meant to say with 2481 and 1306 there could be at least two 30pt climbing robots at the Wisconsin Regional. And we haven't even seen what the other notable (16, 71, 111, 2826) teams will be bringing.
