Go to Post being surgically altered to have two right hands is a big commitment, but if you wanna drive, and drive well ..... ! - KenWittlief [more]
Unread 11-02-2013, 22:28
JCrusoe JCrusoe is offline
Jacque Crusoe
FRC #3880 (Tiki Techs)
JCrusoe is an unknown quantity at this point
Multitasking
After a good hour or so of reading through documentations and any other related page I could find, creating new tasks has me stumped. I'm not sure exactly where to put the line of code the documentation shows as an example, or where to point the function to (do I just leave it as FUNCPTR?).
Task myTask("taskname", (FUNCPTR) functionToStart)
Basically I'm extremely confused haha. I've tried many off the wall things like creating a new object that is a task, and then modifying that line to put in the initialisation. If someone could point me in the right direction I would be eternally grateful =)
Jacque
Unread 12-02-2013, 01:23
Tanaythan's Avatar
Tanaythan Tanaythan is offline
Programmer
AKA: Tanay Nathan
FRC #3256 (Warriorborgs)
Tanaythan is an unknown quantity at this point
Re: Multitasking
The most common way of implementing a new task is using a static void in an object's class. The compressor class uses a task to monitor the air flow, etc. If you want to write a task, you can take a look at the .cpp of the compressor class. Here is some sample code too.
This is a sample header file.
class Sample {
public:
//constructor, other functions
private:
Task task;
static void TaskRunner(Sample *s);
And here is the corresponding .cpp
Sample::Sample() :
task("Sample Task", (FUNCPTR) TaskRunner)
task.Start((INT32)this);
void Sample::TaskRunner(Sample *s) {
//Task code here
Tanay Nathan
Programmer
Team #3256 Warriorborgs
