Go to Post it's called the Mars Rock automode (you sit there and wait for Opportunity to come along). - EricH [more]
Unread 02-12-2013, 05:21 AM
r0306 r0306 is offline
AKA: Robert Lu
FRC #0253 (MRT)
r0306 is an unknown quantity at this point
NullPointerException at drivecode
When we run our drive code, it throws the following error:
[cRIO] java.lang.NullPointerException
[cRIO]     at edu.wpi.first.wpilibj.RobotDrive.arcadeDrive(RobotDrive.java:342)
[cRIO]     at edu.wpi.first.wpilibj.RobotDrive.arcadeDrive(RobotDrive.java:354)
[cRIO]     at Robot2013.RobotMain.teleopPeriodic(RobotMain.java:90)
[cRIO]     at edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:165)
[cRIO]     at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase.java:169)
[cRIO]     in virtual method #10 of javax.microedition.midlet.MIDlet(bci=17)
[cRIO]     at javax.microedition.midlet.MIDletTunnelImpl.callStartApp(64)
[cRIO]     at com.sun.squawk.imp.MIDletMainWrapper.main(110)
[cRIO]     in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO]     at com.sun.squawk.Isolate.run(1506)
[cRIO]     at java.lang.Thread.run(231)
[cRIO]     in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO]     in static method #3 of com.sun.squawk.VM(bci=6)
public class RobotMain extends IterativeRobot
    public static RobotDrive driveTrain;
    public static Joystick leftStick;
    public void robotInit()
        driveTrain = new RobotDrive(4, 3, 1, 2);
        driveTrain.setSafetyEnabled(false);
    public void autonomousPeriodic()
    public void teleopPeriodic()
        driveTrain.arcadeDrive(leftStick); //line 90
    public void testPeriodic() {
The motors aren't running at all and I don't get what could've gone wrong here as the code seems fine.
Scrambled Eggs for the children
Unread 02-12-2013, 05:44 AM
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: NullPointerException at drivecode
You never instantiated the joystick so there is no Joystick to get any values from.
Joystick leftStick = new Joystick(1);
