Go to Post Thankfully, no magic smoke was released during the making of these photos. - SteveGarward [more]
Unread 11-02-2013, 22:03
ILikePizza555's Avatar
ILikePizza555 ILikePizza555 is offline
AKA: Isaac Avram
FRC #2761 (CN Ironhorse)
ILikePizza555 is an unknown quantity at this point
Button Checking Code lags Teleop.vi
I have some code that I'm using to check button presses on a joystick. It looks like this:
For some reason this code keeps hanging the program, and it takes forever to send output to a motor. I verified this but wrapping it in a disabled diagram block. Any workarounds?
PONIES ARE STOOPID MAGIK -Heavy
Unread 11-02-2013, 23:16
propionate's Avatar
propionate propionate is offline
Team co-lead and LabVIEW programmer
AKA: Stephen
FRC #1732 (Hilltopper Robotics)
propionate is on a distinguished road
Re: Button Checking Code lags Teleop.vi
I'm a little confused as to why you have contained your separate motor control VI's in a flat sequence. Are you attempting to run these controls in a particular order if a certain combination of buttons is pressed? If not, there is no need for the flat sequence structure.
Unread 12-02-2013, 07:11
I assume you placed that code into teleop. If teleop doesn't read the joysticks and update the robotDrive many times per second, it will act as you describe. Once your sequence starts, the delays prevent teleop from doing the robotDrive task.
What most teams do is to move the code you've shown into periodic tasks. That way teleop can run quickly and return to the scheduler.
Greg McKaskle
Unread 12-02-2013, 20:03
AKA: Isaac Avram
I had the idea that it was running too many things at once, and that if I put it into a flat sequence structure, it will slow down a bit. That, and I'm more used to coded languages such as python or java, the flat sequence make a little bit more "sence" to me.
Greg McKaskle
I'll try that tonight, thanks.
Unread 13-02-2013, 01:03
AKA: Isaac Avram
Found out that it wasn't the button checking code, but the fact that SetOutput causes some sort of lag for some reason when it trys to set motor output on a jag that doesn't exist. Is this normal?
Unread 13-02-2013, 09:42
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Yes, this will happen when you try and access a refnum that hasn't been previously opened. If you look on your Drive Station at the error messages, you'll see your program throwing an error of that nature. Your code will slow down noticeably when there are errors being thrown, as handling them takes processing power away from your main code.
