Go to Post Its always good to read the rules yourself rather than listen to "word of mouth" rules. - Killraine [more]
Unread 11-02-2013, 13:13
theboyer theboyer is offline
FRC #3965
theboyer is an unknown quantity at this point
New Programmer
Hi,I'm a new programmer and I was following a tutorial and it kept using a certain vi,but i couldn't recognize it or find it in the tool pallet.Can someone tell me what it is and where to find it
Unread 11-02-2013, 13:20
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: New Programmer
Feedback node. Located in the Programming -> Structures pallet.
James H James H is offline
FRC #4256
James H is an unknown quantity at this point
Re: New Programmer
That is called a feed back node. It stores the last value fed in so that you can compare a variable or value to itself. It is found in the Structures pallet towards the bottom right.
Unread 11-02-2013, 13:34
FRC #3965
Re: New Programmer
Thank You
Unread 11-02-2013, 14:12
FRC #3965
Re: New Programmer
Oh one more.Sorry for the nuisance
Unread 11-02-2013, 14:15
Team3763 Adam Team3763 Adam is offline
Lead Programmer
FRC #3763 (4H WildCards)
Team3763 Adam can only hope to improve
Re: New Programmer
No need, that's why we're all here; to help.
That is a Boolean> True/False. Depending on which letter, T or F, has green behind it tells you which is running. (i.e. Green-background T means it's running True).
Unread 11-02-2013, 14:46
Re: New Programmer
The feedback node is found in the Structures palette. It points from right to left by default. The diamond underneath it is how older versions of LabVIEW marked the initializer terminal; this year it looks like an asterisk which becomes a cursive i when wired.
The green T/F is a Boolean constant from an older version of LabVIEW. It would alternately highlight the T and the F when clicked on. LabVIEW 2012 instead displays it as a single square with either a T or an F in it. You'll find the T and F constants in the Boolean function palette.
Unread 11-02-2013, 17:56
FRC #3965
Re: New Programmer
Now I'm trying to insert a process much like this which will set a servo to 90 activate a relay forward and then set both of them back to their natural position
but it seems to be running too fast and starving the drive system any pointers
Unread 12-02-2013, 00:08
Re: New Programmer
Now I'm trying to insert a process much like this...
Unless we see what you're actually doing, we won't be able to give much in the way of help. Show us your code, not the example you're emulating.
Unread 12-02-2013, 00:34
FRC #3965
Re: New Programmer
oh sorry yes here
Unread 12-02-2013, 07:15
Re: New Programmer
If you place the code into teleop, it will prevent teleop from running frequently enough. Try moving it to Periodic tasks.
Greg McKaskle
Unread 12-02-2013, 09:31
Racer26 Racer26 is offline
Re: New Programmer
I can't be the only LabVIEW developer that despises the use of the feedback node, can I? IMO, while feedback nodes *can* make a diagram cleaner, they actually make it *harder* to understand, as compared to using the equivalent shift register.
Unread 12-02-2013, 16:43
FRC #3965
Re: New Programmer
I attempted this and it still says it is starving the drive loop
Unread 12-02-2013, 17:37
Re: New Programmer
You can attach your vi's directly to a post.
Show us your Teleop.vi & Periodic.vi, and any other vi you might have added code to.
The code you posted looks fine as long as it's in Periodic Tasks.vi (it would not work in Teleop).
Unread 12-02-2013, 19:56
Re: New Programmer
I can't be the only ...
I also learned LV long before there were shift registers and in many ways prefer them, but I now use both, typically for different things. I really like the compare to last with a shift register, but otherwise typically use shift registers.
Greg McKaskle
