Go to Post And like Woodie told us in his talk, all the bad stuff we anguished over will be replaced by the memories of the achievements and good time we had this year. - Wayne C. [more]
Unread 11-02-2013, 22:28
wag2625 wag2625 is offline
FRC #2625
wag2625 is an unknown quantity at this point
Camera image crashing code???
Hello. We are working on the vision tracking component of our robot in Windriver and noticed that when we attempt to retrieve the camera image for filtering and particle analysis, it seems to crash our code.
When we enter Autonomous mode the code runs up until it is supposed to read the image from the camera. After that, the program freezes and we are unable to communicate in either Autonomous or Teleoperated mode, and need to reset the cRio in order to continue.
Any input would be greatly appreciated
Unread 12-02-2013, 09:52
Re: Camera image crashing code???
Enable NetConsole and see what the cRIO tells you as it crashes. It'll probably have an error message with a clue about the cause of the problem.
Unread 14-02-2013, 19:56
aziobro aziobro is offline
FRC #4475 (Terrier Byte Bots)
aziobro will become famous soon enough
We are seeing the same problem with our code.
There seems to be a problem with the image from the axis camera.
If we check the height and with of the image we get 0.
Even when the GetImage returns true (1) the height and width still say they are 0.
We are using the vision sample code and add the following to check the height and width.
ColorImage *image;
int cameraimagegood = camera.Getimage(image)
int width = image->GetWidth();
int height = image->GetHeight();
We checked the camera setup and it looks correct. (User FRC Password FRC)
The Camera Image is getting to the DashBoard.
We are able to run in debug mode and set breakpoints to check values.
We are stuck.... Any suggestions?
