Go to Post you know you have overdosed to first when while you are reading all of these things, you can smile and say "oh yeah, i miss doing that" and then, you start to tear up and scream "I MISS FIRST!!!" - amanda547 [more]
Unread 12-02-2013, 13:51
David++ David++ is offline
Rookie Year: 1900
David++ is an unknown quantity at this point
Re: Deadzone Programming
Originally Posted by DjMaddius View Post
Try this, you need to set default values. Also I just cleaned it up a bit.
void driving(){
	double y = 0;           //variable for forward/backward movement
	double x = 0;           //variable for side to side movement
	double turn = 0;        //variable for turning movement
	double deadzone = 0.3;	//variable for amount of deadzone
	if(driverStick.GetY() > deadzone || driverStick.GetY() < -deadzone) {
		y = driverStick.GetY();
	if(driverStick.GetX() > deadzone || driverStick.GetX() < -deadzone) {
		x = driverStick.GetX();
	if(driverStick2.GetX() > deadzone || driverStick2.GetX() < -deadzone){
		turn = driverStick2.GetX();
Instead of checking for both the positive and negative deadzone, you can just take the absolute value. In addition, you can reduce the number of function calls to GetX() and GetY() by assuming the value is valid and handling the exceptional situations.
#include <math.h>
void driving() {
    double y = driverStick.GetY();
    double x = driverStick.GetX();
    double turn = driverStick2.GetX();
    if(fabs(y) < deadzone)
        y = 0;
    if(fabs(x) < deadzone)
        x = 0;
    if(fabs(turn) < deadzone)
        turn = 0;
Or, if you prefer the compact Arithmetic If operator:
#include <math.h>
void driving() {
    y = ((fabs(y) < deadzone) ? (0) : (y));
    x = ((fabs(x) < deadzone) ? (0) : (x));
    turn = ((fabs(turn) < deadzone) ? (0) : (turn));
